so these wheels fit?
Old Mar 1, 2011 | 08:08 PM
Jairo's Avatar
im looking into buying these wheels
http://www.jegs.com/i/Cragar/260/397...oductId=754162
and from my understanding (according to this chart)
https://www.rsracing.com/images/tech-wheeloffset.gif
i will need a 5.5 back spacing to make these wheels fit but these wheels only come with a 4" backspacing. so, if i get a 1.5" spacer can i make these wheels fit?
or am i just confusing the hell out of myself? please help!!! thanks!!
Old Mar 1, 2011 | 08:11 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: so these wheels fit?
a spacer will make the fitment worse, you ideally need 6-6.5" of bs. 5.5 will put the wheel just outside the wheel well.
Old Mar 1, 2011 | 08:29 PM
Jairo's Avatar
wouldnt a spacer technically give it more bs??
Old Mar 1, 2011 | 08:30 PM
Jairo's Avatar
i honestly just want to fit a 295 tire in the rear and i know with a 10" it WILL fit.
Old Mar 1, 2011 | 08:42 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
no, a spacer reduces the amm0ount of back spacing, it bolts to the wheel, and reduces the distance from the mounting surface of the wheel to the inside lip, which is the backspace measurement.
it increases the negative offset.
Old Mar 1, 2011 | 08:43 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
a 296 cna fit on teh factory 16x8.
you need 5.5": of BS at the very minimum, but like i already said 6-6.5 would be best, but may require some inner wheel well hammering and such.
Scamo-2.8
May 20, 2016 07:01 PM
kah992
Aug 19, 2015 02:55 PM
greeny
Wheels and Tires
Aug 12, 2015 03:55 PM
milk
Aug 10, 2015 06:26 PM
