Tire size question
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
Tire size question
I am thinking of going to a 245/50/16 instead of a 235/50 on my RS. I was told they would fit on my stock wheels and they wouldn't rub.
I want some TGO input before I go ahead with this..
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Tire size question
245/50-16 is the stock sized 16" tire.
Only rubbing issues you could have, would be if your car originally came with 15"s & the steering stops in the steering box. For the 16" wheels, the steering boxes had different stops built in than for 15" wheels, because of the different backspacing/offset of the wheels & tire width.
Car: 87 Camaro
Engine: 305 LG4 (H)
245/50r16 will work no problem. OP your thinking of a 235/55r16, which is standard on a lot of F bodys as well. Nothing wrong with a 235 either, its not like there is going to be any traction difference with the same tire with only 10mm width difference.
Well, 10 mm isn't much indeed. The 235's were more expensive than the 245's. Why, I don't know, but I'm leaning toward the 245's. I should check into 255's as well.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
depending on your ride height and alignment, the tire may rub the plastic fender liner a little at full lock, but nothing major
Car: 86 Trans Am
I see no reason not to opt for the 245 directional tire. I have had my existing kumo tires catch puddled up water on the highway. I would call it hydroplaning. Probably due to the tread design, not the width. kumo is a low end tire. Not my preference.
toronto formula
Nov 10, 2015 06:17 AM
knight72
Aug 10, 2015 09:32 PM
