Whats the difference?
Old Apr 15, 2011 | 09:47 AM
89/91rs's Avatar
Car: 89 camaro rs
Engine: 2.8L v6
Transmission: ?
Hwy, when i bought my 89 camaro rs, it had some sort of drag radials on the back, not quite sure why thought. well one of them went flat, and i dont really want to spend money on a new one, so how does the rim size thing work? Would i have to spend money on a new rim for a stock tire, or does it fit right on? any help would be great.
Old Apr 15, 2011 | 03:12 PM
lb9 GTA's Avatar
Car: '88 Trans Am GTA
Re: Whats the difference?
We would need more information than that. What does it say on the side of the tire alredy mounted? Do you have any pics of the wheel and tire in question? Did it go flat just sitting? Did you drive on it low and damage it? It may be repairable. The more info you provide the faster and more accurite you can be helped
Old Apr 15, 2011 | 03:44 PM
89/91rs's Avatar
Car: 89 camaro rs
Engine: 2.8L v6
Transmission: ?
yeah...i saw it was gettn low, so before i had a chance to air it up...oh and by the way it was runnin on about 80% air when i noticed. i let it sit a few days over the weekend planning to do it monday morning, but it was copmpletly flat. how do i upload pics?...the tire is a stinger radial gt/s... and i think i see a puncture hole on the side. it might just be a plug problem, but i know side wall punctures are a little more troublesome then others. so any help would be great.
Old Apr 15, 2011 | 03:46 PM
89/91rs's Avatar
Car: 89 camaro rs
Engine: 2.8L v6
Transmission: ?
Old Apr 15, 2011 | 03:51 PM
lb9 GTA's Avatar
I use photobucket to upload pics. Get air in it and spray it with soapy water and see where its leaking from. Sidewall punctures are not repairable as the rubber is too thin and may blowout after the repair.
Old Apr 15, 2011 | 03:54 PM
89/91rs's Avatar
Car: 89 camaro rs
Engine: 2.8L v6
Transmission: ?
yeah thats what i was afraid of...bummer. well thats a pain in the ***...thanks. now if i wanted to put normal size tires on the car, would i have to get new rims to fit the new rubber?...will post pics in a sec
Old Apr 15, 2011 | 04:00 PM
89/91rs's Avatar
Car: 89 camaro rs
Engine: 2.8L v6
Transmission: ?
http://s1215.photobucket.com/albums/...ignment017.jpg
Old Apr 15, 2011 | 04:01 PM
89/91rs's Avatar
Car: 89 camaro rs
Engine: 2.8L v6
Transmission: ?
http://s1215.photobucket.com/albums/...ignment016.jpg
http://s1215.photobucket.com/albums/...ignment015.jpg
Old Apr 15, 2011 | 04:45 PM
lb9 GTA's Avatar
I need to know the size of the tire that's on there to answer that question. Its the number on the sidewall that looks like P245/50R16 for example. Those look wider than stock tho.
Old Apr 15, 2011 | 06:34 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Thats not a drag radial its a passenger tire.
Top / Tires / Passenger Car Street Tires / Dean Stinger Radial GTS Passenger Tire
The Dean Stinger Radial GTS Passenger Tire is designed for maximum comfort on the road.
Manufacturer: Dean
50,000 Mile Treadwear Protection Limited Warranty
Even-Wearing Design
A notched, solid center rib, along with a refined tread element shape, helps provide even treadwear. Shoulder slotting is also designed for resistance to irregular wear while providing solid, all-weather performance.
Quiet Ride
Pitch sequence has been optimized to reduce tread related tire noise for iscreased consumer riding comfort.
M+S Rated
ire.
Old Apr 15, 2011 | 08:10 PM
Engine: TBI,5.0
Sorry, double post.
69GTOby
Apr 18, 2016 02:34 PM
scottmoyer
Sep 20, 2015 11:54 AM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
greenyone
Sep 2, 2015 03:39 PM
