I need some backspacing help
Old May 3, 2011 | 01:04 PM
ReNeGaDe_Z's Avatar
Car: 1990 Formula, 1989 Mustang LX
Engine: Stock TBI 305, Built 302
Transmission: 700R4, AOD
Axle/Gears: 4.10, 4.10
Im looking to put a 275/60/15 on the back of my Formula, Im also going to order a new set of wheels. Im just not sure how much backspacing to get on them. A set of 15in Cragar steelies with 4in of backspacing and 255/60s stick out a little from the wheel wells. I dont think 4in of backspacing is enough. Can anybody help me out?
Old May 3, 2011 | 07:52 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: I need some backspacing help
that all depends on how wide the wheels are. backspacing is meaningless without also having the wheels width.
Old May 3, 2011 | 08:52 PM
ReNeGaDe_Z's Avatar
I'm sorry. I thought I had that up too. I was planning on ordering a set of 15x8s from Bassett. The Cragars are also 15x8. I read some other threads that said for a 275 tire on a 15x8 rim that a 5in backspace was recommended. Is a 15x8 with 5in of backspace what I should order?
Old May 4, 2011 | 05:48 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
5 would be better with the wider tire, but may still rub a little in the front of the inner fender well, down low. not a big deal. the factory "rear" 16x8's are 5.125 BS.
you should be fine
Old May 4, 2011 | 06:32 PM
ReNeGaDe_Z's Avatar
Thanks man. But I looked at Bassett's website again and they only offer their DOT wheels with up to 4.75in BS. Is that going to be enough? I don't mind if they stick out a little from the wheel wells, but I don't want it to look ridiculous.
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
brockerboy
Wheels and Tires
Sep 17, 2015 03:59 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
rb85TA
26
Sep 14, 2015 10:29 PM
Brian Anderson
Wheels and Tires
Sep 12, 2015 06:12 PM
