RS Wheels Question
Old Jun 12, 2011 | 12:23 PM
wilhay's Avatar
Car: 1984 Sport Coupe
Engine: v6
Transmission: 5spd.
RS Wheels Question
Have a set of the ( I think they are called n45 option ) 16" 5 spoke wheels off 92 RS. I noticed that the rear ones have a different offset ( didn't know when I bought them) and assume it's to allow for the rear disk brakes that came with that option package. No. 1, will they fit my car as I have drums on the rear and no.2 will they set to far inside the fenderweel. If so is there spacers thick enough to allow for this with longer wheel studs?
Old Jun 12, 2011 | 12:39 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: RS Wheels Question
Bolt'em up and ride off into the sunset.
JamesC
Old Jun 12, 2011 | 12:42 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Just make sure the rears are on the rear, and the fronts are on the fronts - if you put the rears on the fronts, they rub the tie rod ends. They are marked "front" and "rear" on the inside of the wheel.
Old Jun 12, 2011 | 01:30 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
Old Jun 12, 2011 | 02:05 PM
JamesC's Avatar
IIRC, all 16's, 85+, are marked front and rear (because of the off-set). I suspect the OP is aware.
JamesC
Old Jun 15, 2011 | 07:04 PM
wilhay's Avatar
Engine: v6
Transmission: 5spd.
Great, thanks fellows
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
