hub is too big. what do i do?
Old Jun 18, 2011 | 12:38 AM
abu1421's Avatar
Car: 1986 Chevrolet Camaro
Engine: V6
Transmission: Automatic
I got a set of FREE R1 Racing Rims from my boss as a gift. He had them sitting in his basement for a few years with tires attached and everything.
I went home and jacked up the camaro to put these rims on, but the camaro's hub was too wide for the rims BARELY.
What do i do? i want these rims on my car. thanks everyone
Old Jun 18, 2011 | 12:03 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: hub is too big. what do i do?
take the wheels to a machine shop and have the hun openings opened up. if it its close, you can probably do it with a file or grinder. dont go crazy though, and dont leave sharp edges.
Old Jun 18, 2011 | 02:39 PM
abu1421's Avatar
Engine: V6
do you know how much that would run me? ball park
Old Jun 18, 2011 | 05:58 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
if it's really close you can use a sanding drum chucked in a drill motor . make about 8-10 circular passes about center hole of the wheel . ck. fit , do a couple of more times till it fits . just sand off enough to get a proper fit , you can always grind more off . it's really hard to grind some back on . you can get a sanding drum at Lowes , Home Depot etc. , any drill motor . i had to do this to my new ZQ8 rims a few years ago to fit on my rear drums . piece of cake its so easy to do . good luck .
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
Drone358
Sep 28, 2015 04:55 PM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
Abubaca
Car Audio
Sep 24, 2015 02:33 AM
