wheels
Old Jun 24, 2011 | 05:15 AM
slinger129's Avatar
Car: 1985 iroc
wheels
whats the deal with the wheels on my 85 iroc they can only be installed on certain ones they are marked front and back im thinking i need to put spacers on so they can be mounted anywhere?i want to change wheels so thats why im asking. and im new to the iroc seen just picked it up yesterday thanks
Old Jun 24, 2011 | 06:37 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: wheels
There different offsets and backspacing between the front and back. Same goes for the firebird ones too. You wouldn't be believe how many times shops have told me they can rotate my tires for cheap and I try to tell them the front and backs don't swap out, but they assure me rotation fees cover that then try to charge me $30+ per tire at the end.
Camaro 82-92 16x8 front 0mm 4.35"
Camaro 89-92 16x8 rear 16mm 5"
Old Jun 24, 2011 | 07:16 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: wheels
The wheels are marked (front & rear ) for a reason. The only correct way to rotate tires is to dismoumt them & rebalance which is expensive. Been there and done it at $60 per rotation.
Old Jun 24, 2011 | 08:15 AM
Guest
Guest
Posts: n/a
Re: wheels
The thing is, when buying aftermarket wheels, you don't always need staggered offsets.
Too many people on here are running fronts on all 4 corners, with no spacers, and it works great! Or do the 1LE brakes, then you can run rears on all 4 corners.
Look at that next thread, about snowflakes and lowered. Those 17x9" wheels are close to a zero offset, and they fit fine, on all 4 corners, with no spacers.
That car must not have 1LE brakes.
Old Jun 24, 2011 | 04:49 PM
slinger129's Avatar
Car: 1985 iroc
Re: wheels
thanks guys wish i wasn't new to the 3rd gen scene,sorry if i ask alot of questions that probably were asked already
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
drptop70ss
Oct 4, 2015 09:44 PM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
