OEM Z06 rims
Old Jul 13, 2011 | 06:13 PM
thepatriot1991's Avatar
Car: 1989 Trans Am GTA
Transmission: Built 700r4
OEM Z06 rims
ok I am looking at buying a set of real z06 pulled off of an 02 for my 89 GTA. Ive looked but cant seem to find anyone on here running actual vette rims. Just wondering what kind of spacer i would need to run and how much they might stick out? I have a third gen rear end.
Old Jul 13, 2011 | 06:35 PM
DJ Delsym's Avatar
Car: 86 Iroc
Engine: Soon to be LS 6.0
Transmission: Soon to be mn12
Axle/Gears: Strange 9in 4.10
Re: OEM Z06 rims
Here you go bud.
https://www.thirdgen.org/forums/sear...archid=4205253
Old Jul 13, 2011 | 08:34 PM
3318RS's Avatar
Car: 1990 RS
Transmission: Built-700R4
Re: OEM Z06 rims
Regular C5 wheels are: 17x8.5 & 18x9.5, these require a 2" spacer front & back on a 3rd gen rear. (This is what I have)
C5 Z06 Wheels (01 thru 04) are 17x9.5 & 18x10.5, so if the math is the same, by them being an inch wider front/back they would require a 1" spacer. HOWEVER, this is an educated guess on my part, you have to look-up the offset as that will give the final truth. Good Luck!
Old Jul 15, 2011 | 10:33 PM
Transmetal's Avatar
Car: 89 Trans Am GTA
Engine: 5.7 350 TPI L98
Axle/Gears: Borg-Warner 3.27
Re: OEM Z06 rims
I just 2 mounted C6 Z06 rims on my 89 gta today. Gotta install the other 2 over the weekend. Mine are the OE replicas black in 17x9.5
Old Jul 16, 2011 | 08:14 PM
Re: OEM Z06 rims
Do I need to get longer studs? and does anybody have a picture of a third gen with them?
Old Jul 16, 2011 | 08:28 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: OEM Z06 rims
You don't need longer studs.
The adapters have 5 holes that your stock lugs fit through that the lug nut hold it on to. Then the adapter has 5 studs sticking out that the wheels fit on & 5 more lug nuts hold the wheels on.
http://www.skulte.com/adapterfaq.html
Old Jul 16, 2011 | 08:47 PM
lonesomeloser's Avatar
Car: 1983 Z28
Re: OEM Z06 rims
https://www.thirdgen.org/forums/whee...eels-post.html
Old Jul 17, 2011 | 08:43 AM
Transmetal's Avatar
Re: OEM Z06 rims
Took a quick pic of the rims, I'll get better pics of the whole car when it's not so humid. Kinda crazy that way up here in MN it gets so muggy that the camera lens keeps fogging up.
Old Jul 18, 2011 | 08:20 PM
Re: OEM Z06 rims
does anyone know if they will stick out much?
Old Jul 18, 2011 | 09:58 PM
Transmetal's Avatar
Re: OEM Z06 rims
Mine barely do if at all. The front ones don't, the back do a little but it looks like my rear end isn't totally center which my panhard bar should take care of.
Old Jul 19, 2011 | 02:12 PM
Re: OEM Z06 rims
how wide are those tires?
Old Jul 19, 2011 | 04:59 PM
Transmetal's Avatar
Re: OEM Z06 rims
275 40 17 on all 4.
Old Jul 23, 2011 | 03:03 PM
Re: OEM Z06 rims
ok thanks man
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
dbrochard
Oct 10, 2015 01:03 PM
