16x8 GTA wheels on 1985 T/A?
Subscribe
Sep 9, 2011 | 04:25 PM
Hi, new user here. Just purchased a 1985 Trans Am.
Will I have any problems fitting 16x8 GTA wheels on my car?
Reply 0
Sep 9, 2011 | 06:47 PM
Re: 16x8 GTA wheels on 1985 T/A?
no, they will fit just fine
Reply 0
Sep 9, 2011 | 06:52 PM
Good thanks
I'm not a big fan of using spacers, want to avoid that.
I am however a big fan of wider wheels and tires in the back than up front, but I understand the GTA was delivered wit 8" with both on the front and back?
Reply 0
Sep 9, 2011 | 06:57 PM
yes, they are both 16x8, the front wheels have zero offset, 4.5" of backspacing, the rears have 16mm offset, or 5.125" of backspacing.
there are Front and Rear wheels, they are marked of the backside
you can put the front wheels on the rear of the car, but you cant put the rears on the front unless you use a small spacer or have the 1le brake package.
Reply 0
Sep 9, 2011 | 07:54 PM
Quote: yes, they are both 16x8, the front wheels have zero offset, 4.5" of backspacing, the rears have 16mm offset, or 5.125" of backspacing.
Ah, ok, Thanks alot.
Reply 0
Sep 10, 2011 | 01:25 PM
Any suggestions on what size tires to fit on these?
I would like it a little wider in the rear than the front. Can I go 255 in the back and 235 on the front without going "out of limits"?
Reply 0
Sep 10, 2011 | 01:29 PM
245/50/16 is a commmon size used front and rear. you can use the 255 front and rear too AFAIK. your plan to use 255 and 235 tires will be fine, so long as they are of a stock height of about 25.7"
Reply 0
Sep 10, 2011 | 03:19 PM
Thanks alot, believe I'll go for that then. 50 profile all around...
Reply 0
Subscribe
