Best tires for my car.
Car: 1988 Camaro, Holley 600 series.
Engine: 350 w/350 TPI heads
Transmission: 90+ 700R4
Axle/Gears: not sure
I have a 1988 camaro, 115-65-R15 s What would be the best performance tire for my car. If you just lend me your opinions that would be great. You know; What you guys like to use on your cars then ill do some research and see what I like best. Then ill buy them =D
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Best tires for my car.
115's? what are those, spares?
what wheels do you have? need to know the width first...
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Plus what do you want to do? What look do you want? How much money do you have?
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
I think he means 215-65-15's.
You can do 225/55/15 front, 225/60/15 rear
or 225/55/15 front& rear
I want performance tires that have a lot of traction and are good for taking turns and help in not hydroplaning. I have a guy that I can get pretty much any tire for really cheap so money isn't an issue. Should I have 225? would that be better?
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
You don't mention your wheel sizes other than 15s but I can still tell you what tire sizes I think look good on a car with 15's and set up like mine.I am running 235/60r15s on 7x15 wheels front and 255/60r15s on 8x15 rear. I like the staggered look this gives me and IMO the more rear tire on the ground the better. I also think the 235 tire in front is perfect for that look.I don't care for a thin tire. As far as a performance tire for 15in. wheels they are getting harder to find with only a small selection available. I went with a street all season because mine is a DD and wont be seeing the track. Sorry but I have no experience with a hi performance tire. I just wanted to tell you my tire size preference on a car set up like mine.
Car: '85 Z28
I run 235/60/15 up front and 245/60/15 out back.
Here's a good link for tire size calculations: http://www.miata.net/garage/tirecalc.html
Car: 1992 Camaro RS - medium quasar blue
Engine: 5.0 l. 305 cid. TBI L03 VIN E
Transmission: TH-700R4
Axle/Gears: 10 bolts 28 splines 7.625" 3.23
225/60/W15 is another excellent option (front and rear) I bought for my 92 RS high performance Kumho tires model Solus KH15 with speed rating W (270 kmh.) very adaptive to wet & dry roads, low noise, high-speed stability and lateral grip under cornering. http://www.kumhotire.com/tire/tire_d...jsp?prdt_id=25
1992rs/ss
Jan 31, 2025 05:10 PM
