1.75 spacer for front 2.0 for the rear?
Old Oct 7, 2011 | 03:37 PM
blackgloves's Avatar
Car: 1987 IROC-Z
Engine: 6.2L
Transmission: Stage III T56
I've almost given up on this forum. Seems like all my questions go unanswered. I have to thumb through tons of pages from old threads to find answers and even then I don't get them answered fully.
Can I go with a 1.75 spacer up front and a 2.0 in the rear?
The wheels I bought are 17 X 9.5 (front) and 18 X 10.5 (rear) Corvette C5 wheels. black matte with polished lip. The car is a 84 Z28. The tires are 245 and 285. Looks like Ill be going with Hankooks for tires
Old Oct 7, 2011 | 03:54 PM
jwdomino's Avatar
Car: 82 Trans Am
Engine: 13:1 383 stroker on e85
Transmission: t-56
Axle/Gears: ford 9" locker 3.70
Re: 1.75 spacer for front 2.0 for the rear?
sure, do it
Old Oct 7, 2011 | 03:57 PM
Car: 1987 IROC-Z
Engine: 6.2L
the reason I have asked is that I want my front wheels to tuck under as deep as possible without issues. A little rubbing here and there is not a big deal as long as its not rubbing all the time. I want the rear tires to look much bigger than the front tires. I want the skinnies and fatties thing going without actually going with skinnies and fatties.
Old Oct 7, 2011 | 06:38 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
no one answers because they get sick of answering the same questions 2-3 times a week.
the ONLY way to get the wheels to fit how you want them to, would be to get them ,mount tires, remove you wheels and physically place the wheesl in the wheel wells where you want them, and then measure back to the hub for the spacer size.
if you provide the offset or the backsapcing (useful info for wheel fitment), then we may be able to do some quick math, but without, its hard for somebody without the same exact wheels to do anything.
Old Oct 7, 2011 | 09:46 PM
Car: 1987 IROC-Z
Engine: 6.2L
front 17x9.5 +54mm
rear 18x10.5 +56mm
This is the only info I see
http://www.corvette-wheels.com/c5-d-...ished-lip.html
Old Oct 8, 2011 | 11:53 PM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
I other question. Are you running the factory front brakes? I have 17X9.5 w/50mm offset and 2" spacers and 13"C5 front brakes and dont think I could have cleared with only a 1.75 before the C5 brakes. Think I could barely clear them now, the tie rod being the first thing to hit. It would be close!
Old Oct 9, 2011 | 01:20 AM
Car: 1987 IROC-Z
Engine: 6.2L
Factory brakes yes. wanna upgrade in the future. one step at a time.
customblackbird
Aug 15, 2021 10:16 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
kah992
Aug 19, 2015 02:55 PM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
