Tire balancing
Old Nov 5, 2011 | 08:53 PM
herders's Avatar
Car: 1986 Firebird
Engine: V8 305
Tire balancing
Hey All,
I am wondering. I am in the process of polishing my rims and getting new tires put on. I would be disappointed if the the weights were put on the front of the rim and destroy the appearance. Can these weights by attached to the inside of the rim??
Paul
Old Nov 5, 2011 | 09:49 PM
dans89's Avatar
Car: 85 z28
Re: Tire balancing
OE third gen rims aren't designed for that. Theoretically it could be done with tape weights, but even if it is possible (which I'm sure it is) the wheel/tire wouldn't be balanced correctly and you will most likely end up with vibrations. You could always have them static balanced. That's where the wheels are balanced on one plane instead of both planes, but you will probably still end up with vibrations and there's no telling which side of the wheel is going to call for weight. Honestly it's better to just bite the bullet and have them dynamic balanced with clip on weights. After all, what's the point of having a nice looking ride if it's a nightmare to drive?
Old Nov 5, 2011 | 10:31 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: Tire balancing
it's called static bal.
and yes it works fine. all my drag wheels are done that way..
rides has smooth has Glass.
they make about 10 diff typs of weights. to clamp on to your rims
not just the Tape weights (yuck).some guys use them.(always clean your rims first)
installed with a small dead blow hammer they snap over the inside lip of the rim.
make sure the tire shop you use knows what they are doing..not all do.
i worked for Ford and GM doing tires. this is how I know
with todays tech. you should never see a weight on the outside of a rim!
Old Nov 5, 2011 | 10:40 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: Tire balancing
I took my car into Discount Tire to get them rotated. They took the weights off the outside and put them on the inside when they swapped tires. I'm running the stock GTA honeycomb wheels.
(And yes, they did actually take the tires off the wheels due to the front/rear differences on GTA wheels) and not simply put the whole tire/wheel from the rears on the fronts and vice versa.
Old Nov 6, 2011 | 01:17 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Tire balancing
If they're taped, take a picture of the weights on each (and number each wheel) so if they fall off, you can replace them. I had 245/50 tires put on a few years ago and many of the weights they put on fell off so I had to replace them myself. (they wouldn't offer any balancing guarantee because I didn't want clip-on weights. :shrug: )
Old Nov 12, 2011 | 01:51 PM
Re: Tire balancing
most of the tire shops have Kids working for them $9hr
toss them a Coke and a smile. (tell me it's not true)
and they dont take time to clean the wheels before they place the stick on weights on them. and they will Fall off. and just moving the crud around. dont cut it.. must be clean = stick on.
we all know this..but try to tell them / ask them. did you clean the wheels before. and you get the.
We have Been Doing Tires for a Long Time..
they have had a tire shop name for a long time (MABY)..LOL
your name maby. has been doing them for years.. But how about the Kids you have doing your tires..do they know??
always check you stuff when a shop touches your Car!
jrdturbo
Mar 31, 2016 02:58 PM
italiano67
Sep 22, 2015 08:42 AM
F-body-fan
Sep 17, 2015 12:16 PM
2MNYMaros
Sep 15, 2015 11:36 PM
Magman
Sep 13, 2015 12:14 AM
