Stacking wheel spacers (stud kind and slip on)
Old Nov 7, 2011 | 10:45 AM
4.8camaro's Avatar
Car: '89 Camaro
Engine: 4.8, ls9 cam, mpt76
Transmission: Built 4l60e, 3600 stall TC
Found some 1 1/4 inch spacers (stud kind) at summit in clearance for 50 bucks (normally 130), but I need at least 2 inch of spacing for my zo6 replica wheels. Question is, can I buy these and buy some 3/4 inch slip on spacers along with longer/stronger studs and still be safe? I am only running spacers in front because I have a 4th gen rear.
Also, if I can do this, what would be better/safer: slip on spacer before stud type spacer or after?
Any suggestions/ opinions appreciated
Old Nov 8, 2011 | 11:19 AM
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
Transmission: Megaraptor
Re: Stacking wheel spacers (stud kind and slip on)
can you run them? yes. is it safe, probably not.
ive run the slip on spacers from the rear in the front with the bolt ons, but u r taliking maybe an 1/8''
just buy the 2" adapters,, your safety is not worth $80
Old Nov 17, 2011 | 07:27 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Many will tell you one spacer is not safe. NHRA will not allow them.
Many will tell you they are okay.
I don't think anyone would say its a good idea to stack them.
Old Dec 4, 2011 | 08:42 PM
R0ach88ss's Avatar
Car: 88 camaro
Engine: 305 TBI
Axle/Gears: Stock crap on its way out
I have a full set of Skulte 2" adapters with only about 400 miles on them that I have no use for. If interested shoot me a pm.
Amillionoh7
May 24, 2020 08:01 AM
deracer
Apr 11, 2016 12:04 AM
Horridbulldog
Wheels and Tires
Feb 13, 2016 07:22 AM
kah992
Aug 19, 2015 02:55 PM
