ronal r15 fronts hit tie rods
i have the ronal r15 on my 91 formula 17x9.5 the fronts hit the tie rods i have what looks like 1/4 spacers but no luck put 2 on one side still no luck any ideas? tires r 275/40/17
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: ronal r15 fronts hit tie rods
these wheels will fit a car with the 1le front brakes or a floating rotor type brake upgrade with no spacers. With stock brakes you need a 1\4 or 6mm spacer. If that is not working for you something is wrong. Does this happen on both sides?
yes if i remember right both sides did it i have 1/4 spacers put 2 on one side and still hit the tie rods un sure of the le brakes all i know is factory brakes i did put new tie rods on awhile back
Car: 86 Trans Am
If you do sell I may be interested. Pm me
Engine: 4++,350 & 305 CIs
Any chance of posting some pix of how bad it is??
Car: 86 Trans Am
You can use the factory spacers from the rear that some of these cars used.
The R15 wheels were designed to b used with 1LE brakes and they move the wheel outboard a lil bit.
You have stock brakes??
Car: 86 Trans Am
I have heard recently that the origional ronal wheel spacers were almost 1/2" thick. That's new to bme and may explain why you are having this problem
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Indeed you need spacers with original R15 wheels due to SLP measuring them for the optional Brembo brake system, which (if I remember correctly) is about 3/8" further out then stock brakes.
This is a pic of the preproduction spacer SLP used. Obviously the rotor hat was redesigned for production.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
How much thread engagement are you getting on the lug nuts to wheel studs? Personally I'd think you might be losing too much thread engagement.
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
1992rs/ss
Jan 31, 2025 05:10 PM
ambainb
Apr 25, 2016 09:21 PM
