Replacing 15" Stock Wheel Rims with 16"
Old Jan 16, 2012 | 03:45 AM
cam.crazy's Avatar
Hi,
I have a Camaro 91 RS with 15" stock Wheel Rims and I'm interested to replace them with 16" stock wheel Rims that come with Camaro 91/92 Z28 version.
My questions are:
Q1: Do I need to do any modifications or adding any Wheel Spacers?
Q2: Does the front/Rear 16" Wheel Rims are identical in size?
Q3: Will I have any future problems with Steering pump due to bigger wheel size?
Thanks,
Old Jan 16, 2012 | 06:29 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Replacing 15" Stock Wheel Rims with 16"
My questions are:
No.
Yes.
No.
A Wonderbar would be a good addition.
JamesC
Old Jan 16, 2012 | 06:55 AM
cam.crazy's Avatar
Originally Posted by JamesC
No.
Yes.
No.
JamesC
Thanks for your reply, what about "Lower Control Arm Bumpers" I get to know that there is one for 15" wheels and another one for 16" wheels? also, I've seen many posts talking about wheel spacers, why they are not needed in my case?
Old Jan 16, 2012 | 07:00 AM
JamesC's Avatar
The A-arms have different bump stops:
https://www.thirdgen.org/forums/susp...s-created.html
I'm not sure I'd worry over much about them, especially given the price of the 16" version.
JamesC
Old Jan 16, 2012 | 07:18 AM
JamesC's Avatar
I assume you're speaking of OE spacers (the 10-Bolt FAQ may answer some of your questions):
Why Does My Rear Have Spacers?
The spacer was apparently used on 16" wheels when GM switched from aluminum to iron drums, which created a .187 size difference. The spacer, however, seems to be hit or miss and essentially unnecessary. Even some disc brake cars received them.
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
marcusaw
Aug 10, 2015 08:13 AM
Exxon Limited
Aug 9, 2015 08:13 PM
Fronzizzle
Aug 9, 2015 01:15 PM
