Tire Fitment w/1" drop
Old Jan 28, 2012 | 12:24 PM
BlueWrath92's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 10 Bolt 3.42 Posi
Its a 92 Camaro with a 1" drop, I have a set of 15" AR wheels that I want to put on, I seen a pic of someone with the same wheels with 235/60/15 tires all around and they looked good, does anyone know if this tire size will fit good with a 1" drop? I also believe the backspacing on the wheels is 3.75 if that makes a differance or not.
Old Jan 28, 2012 | 04:49 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Tire Fitment w/1" drop
The backspacing is meaningless with the wheels width. So long as the tire is 25.7 tallish it will be fine, don't go taller in the front.
As for the BS, it doesn't seem to me that they will work, but if you get me the width of the wheel I will know for sure
Old Jan 29, 2012 | 12:07 AM
Car: 92 Camaro RS
Engine: 305 TBI
15 x 7 is the wheel size
Old Jan 29, 2012 | 11:31 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Stock 15x7 has something around 4 so that should be ok
Old Jan 29, 2012 | 12:44 PM
Car: 92 Camaro RS
Engine: 305 TBI
how about my 1le rear with the 12" rotors?
Old Jan 29, 2012 | 01:46 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
the rear pbr brakes were the standard disc brake after 88 or so. They should fit in the 15" wheel, but it also depends on the design of the wheel.
Old Jan 29, 2012 | 01:50 PM
Car: 92 Camaro RS
Engine: 305 TBI
Thanks I appreciate it. Ive been away for a while I will just have to try them when I come home.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
SG91camaro
Sep 5, 2015 10:27 PM
Formula_88AE
Sep 3, 2015 01:47 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
