should I return this wheel adaptor to Hawks?
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
So I recieved my 2" wheel adaptors today and one I am not so sure about. It looks like it got dropped on the edge and what worries me is the flange face has a slight bubble to it. I am not sure if this would effect it as it is aluminum and the rotor hub is steel so I would think the adaptor would be the one to give when torqued down. Additionally I an not sure that edge even makes contact. Thoughts?
Additionally how are you guys torquing these on? When I torque the wheels on a car I always snug them up first while in the air, then lower the car till the tire touches the ground to keep it from spinning as I put final torque on. Not sure how to keep it from spinning while when bolting it on.
Car: 84 Z28
Engine: 91 L98 long block with Pro-jection
Axle/Gears: 91 10bolt w/ 3.42s and T2R
Re: should I return this wheel adaptor to Hawks?
I'd probably file it down, but that's because I wouldn't have the patience to send it back...
As far as torquing, have someone depress the brake, or use a stick or pedal depressor. Nice thing is that you only have to tighten them when installing them, or when changing hubs...
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Yep, just grind it down and run em.
I used the stick and seat method to hold brake pedal down while I torqued them on.
1992rs/ss
Jan 31, 2025 05:10 PM
morrow
Jan 13, 2024 12:29 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
