OE wheels ZR1
Old May 9, 2012 | 12:45 PM
LivinLarge's Avatar
OE wheels ZR1
Does anybody have any pics of the OE wheels ZR1's on a third gen in 17x11?
If you do please give details on your setup and what had to be done to get them to fit.
Old May 10, 2012 | 07:44 PM
96 Z-Ragtop's Avatar
Re: OE wheels ZR1
Nobody?
Old May 10, 2012 | 08:39 PM
Mailman818's Avatar
Car: 89 firebird bone stock for now
Engine: 2.8L V6
Axle/Gears: B.W 9Bolt 3.27 Posi
Re: OE wheels ZR1
a simple search may help. i believe they have been through every single corvette and other f-body gen rims too many times.
Old May 10, 2012 | 09:13 PM
christian89's Avatar
Car: 89 camaro rs
Engine: 350 ; edelbrock stuff and carb'd ha
Axle/Gears: stock
Re: OE wheels ZR1
If I'm not mistakin I was about to get some and the offset was too much, they needed an inch or more just to fit right, i passed em up since the spacers where 75$ each, I'm sure someone on here can give you some more info. hope this helps good luck
Old May 11, 2012 | 07:07 AM
86firebird350's Avatar
Car: 91 GTA
Axle/Gears: stock
Re: OE wheels ZR1
https://www.thirdgen.org/forums/memb...e-spacers.html
Old May 12, 2012 | 07:26 AM
LivinLarge's Avatar
Re: OE wheels ZR1
Im talking about these
http://www.oewheelsllc.com/Wheels_3/...1-Wheels-black
Old May 12, 2012 | 08:00 AM
C-Titan's Avatar
Car: 91 Z-28
Engine: 360TPI
Transmission: PA Racing 700r4
Axle/Gears: 3:73
Re: OE wheels ZR1
https://www.thirdgen.org/forums/whee...eels-post.html
All the Info and Pictures You Need.....
Old May 12, 2012 | 08:04 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: OE wheels ZR1
Doesn't matter which style, or what they look like, painted or not. All that matters is the 17x11", the 5 on 4.75" lug pattern, and the backspacing. A 7" backspacing will work if you do a bit of clearancing. With a 4th gen axle, you'll need another 1.5" of BS. There are plenty of threads detailing the clearancing required. . We aren't going to just give you what you can find for yourself with a few hours of reading old threads. If it really matters to you, you'll make the time.
Old May 12, 2012 | 08:53 AM
Car: 91 GTA
Axle/Gears: stock
Re: OE wheels ZR1
The only difference is 6mm of offset. Not that big of a deal.
Old May 12, 2012 | 12:08 PM
92 BBC Z's Avatar
Car: Currently have 3 cars and 1 truck.
Engine: 1970&92 Cams,both BBC's
Transmission: LS1 T-56 & PG w/vendor's
Axle/Gears: Built 10 bolt& 9inch w/spool
Re: OE wheels ZR1
How did I get em to fit? Well lets see, I bought them, then put them on. 4th gen rear.Name:  rightfront92Z.jpg
Old May 12, 2012 | 12:10 PM
92 BBC Z's Avatar
Re: OE wheels ZR1
Old May 12, 2012 | 10:07 PM
Car: 89 camaro rs
Axle/Gears: stock
Re: OE wheels ZR1
i like the spoiler with that hood, buddy of mine has the spoiler with a 4 in. cowl, clean car
Old May 13, 2012 | 02:06 PM
LivinLarge's Avatar
Re: OE wheels ZR1
I went threw that thread a couple times. Very few 17x11 ZR1 pictures.
Old May 15, 2012 | 11:45 PM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
Re: OE wheels ZR1
Will they fit? I seem to be reading different things on different threads, some say they will and others say they need adaptors.
92 BBC Z, did you have to use adaptors?
Im looking into getting some (all 4 are 17x9's) and i have the stock spindles and stock 3rd gen disk brake rear end.
Old May 16, 2012 | 08:17 AM
92 BBC Z's Avatar
Re: OE wheels ZR1
2.5" adapters on the front only. 4th gen rear.Name:  000_0002.jpg
Old May 18, 2012 | 02:31 PM
LivinLarge's Avatar
Re: OE wheels ZR1
Any more pics and info?
Old May 18, 2012 | 02:56 PM
92 BBC Z's Avatar
Re: OE wheels ZR1
what else you wanna see? What else you wanna know?
Old May 18, 2012 | 03:48 PM
LivinLarge's Avatar
Re: OE wheels ZR1
Not from you lol. Just in general.
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
Saxondale
Sep 15, 2015 06:42 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
