Can I get away with 1.5" spacers all around?
Old May 16, 2012 | 12:04 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I am going to be running OE Zr1 rims... 17x9.5 fronts and 17x11 in the rear. Back tires are going to be 315/35r17... Can I get away with running 1.5" spacers all around? 2" spacers stick out a bit more than I would like... Also, the 1.5" spacers will work better for when I upgrade the brakes all around as it might push the wheels out a hair more.
17x9.5 w/ 56mm offset
17x11 w/ 50mm offset I believe.
Having them sunk in a bit will be nicer for when I lower the car, I don't want to be scraping because the wheels stick out too far.
Old May 17, 2012 | 06:22 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Can I get away with 1.5" spacers all around?
Bump!
Old May 17, 2012 | 07:10 PM
SCCAjunkie's Avatar
Car: 84 Z28
Engine: 91 L98 long block with Pro-jection
Axle/Gears: 91 10bolt w/ 3.42s and T2R
Simple answer- no.
I just test fitted 17x11s on my car, and you already need the pound the crap out of the inner fender at the front of the wheelwell just to get the tires far enough in that they don't stick out.
Up front, you'd probably run into major interference with the steering arm on the knuckle...
I believe that combo at that offset requires 2" spacers in the back, and 2.25" up front. From what I've seen, there's no room to move inward at all.
Old May 17, 2012 | 07:16 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I have read about people using 2" all around with the same wheels, so I know it is possible. I just sent 1MeanZ a pm about him using 1.5" spacers in the rear, and this is what I got...
Originally Posted by 1MeanZ
When I had the stock axle I ran 1.5" spacers with 315s on the back. I did that for the exact reason you list, I think 2" spacers make the wheel stick out too far. I had to do some extra hammering at the lower front portion of the wheel house, and my bumpstops would drag the rims with the axle at full droop too. Everything cleared fine after some massaging but that was at stock ride height. If you lower it you'll need to roll the fender lips still but it's not a big deal.
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
