please help asap corvette rim fitment
Old May 19, 2012 | 05:56 PM
scagz2.8l's Avatar
Car: 1988 camaro rs
Engine: 2.8l
Transmission: automatic
i just baught corvette rims for my 88 camaro they are 17x8.5 in the front and dont seem to fit. the shock is in the way and the steering thing is inside the wheel. the lugs are hardly getting through the slots right now. is there anything i can buy to make them fit or what should i do? the car is jacked up obviously right now and it doesnt seem to work idk if that would make a difference
Old May 19, 2012 | 06:10 PM
88 Z-ROC's Avatar
Car: 88 IROC-Z (L98)
Engine: Edel. Lwr, SLP Rnrs, Ported Plenum
Transmission: 700R, 2800 Stall
Axle/Gears: 3:42 Posi.(4th gen.) UMI R/Susp.
Re: please help asap corvette rim fitment
A 2" adapter is needed to make the fit.. the backspacing is different..
Hawks sells a set..
And i was given this lifonk below
http://www.ezaccessory.com/Billet_Wh...pters_s/25.htm
For the Corvette/4th gen wheel a 2" adapter is usually whats needed..
Old May 19, 2012 | 06:18 PM
scagz2.8l's Avatar
Car: 1988 camaro rs
Engine: 2.8l
will the rears fit or do i need spacers all around
Old May 20, 2012 | 09:11 AM
88 Z-ROC's Avatar
I believe they'll mount up but they won't "line up.."
Old May 20, 2012 | 04:14 PM
robg91z's Avatar
Car: 1991 Camaro Z28
Engine: 350ci TPI
Transmission: built 700r4
Axle/Gears: 4th gen rear end
Hawks sells a set..
Which one of those would be the spacers? I like the price and i know they have to be 5x 4.75 but whats the difference between all of them in that size
Old May 20, 2012 | 04:34 PM
Mike92Firebird's Avatar
Car: 89 GTA
Engine: 5.7 TPI L98
Transmission: 700R4 w/ Stage 2 shift kit & stall
Save yourself the trouble and buy these.
http://www.ebay.com/itm/4-pcs-5x4-75...-/270924923660
You'll need em at all corners.
Old May 20, 2012 | 07:27 PM
88 Z-ROC's Avatar
http://www.ezaccessory.com/ProductDe...e=5475%2D5475K
These are the 1's I will order next week..
Old May 21, 2012 | 01:45 PM
robg91z's Avatar
Engine: 350ci TPI
so the 7/16 stud thread is one to go with? whats the difference between that one and the 12x1.5? im just making sure i order the right ones so i wont have to be returning things lol
Old May 22, 2012 | 07:48 AM
88 Z-ROC's Avatar
The 7/16 stud is the standard size in our 3rd gens.. I honestly dont know what the difference would be w/ the other measurement..
Old May 22, 2012 | 09:36 AM
cal30_sniper's Avatar
Car: 88 GTA/86 C20 Burb/91 325i
Engine: L98/454/M20
Transmission: 700R4/NV4500/Getrag
Axle/Gears: 3.27 9-bolt/3.73 14 Bolt/3.73 IRS
One is metric and the other is SAE. 12x1.5 refers to 12mm diameter studs. Our cars are metric, not SAE. You'll need the 12x1.5mm studs unless you plan on getting new lugnuts too.
-cal30sniper
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
the_hamturdler
Sep 30, 2015 12:50 PM
