How would they look lowered?
Car: 1990 Camaro RS
Engine: 350 Vortec Demon 650CFM
Axle/Gears: Posi
I like the way my rims look but i think my car sits too high i found a set of lowering springs to drop the front and rear 1.75" is that too much? any opinions?
COTM Editor
Re: How would they look lowered?
That would be just about right! Your car looks like it has a lift kit on it now... of the mud races LOL!
Lower it, you will not regret it!
Car: 1990 Camaro RS
Axle/Gears: Posi
The 1.75" are good? Not too much? And I can just throw them on? No other mods necessary?
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
1.75 would look good - an adjustable panhard rod and 4 wheel alignment after installing the lowering kit would be a good idea
Car: 1990 Camaro RS
Axle/Gears: Posi
Car: 1990 Camaro RS
Axle/Gears: Posi
and yeah i was thinking 1.75 would be good, if i got the springs in and then bought the panhard bar would that be ok or does it have to be done together
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
the panhard bar is oriented horizontally for the most part, and keeps your rear axle centered (left to right). Simply put, when you lower the car with shorter springs, the geometry changes and the panhard bar is no longer the correct length to keep the axle centered in the car, so you need an adjustable one to re-center the rear end. If you dont get one your tires will stick out more on one side than the other, and you'll most likely have alignment issues. But no, you dont have to do both a the same time although it's easier/better to do them both at once.
MrPackstin
Oct 25, 2017 08:09 PM
