Shank style wheels problem
Old May 28, 2012 | 04:21 PM
Solidmetal's Avatar
Hi,
I bought front and rear Centerline Convo pro wheels with shank lug nut seat style and centerline lug shank style nuts(1/2- 20 RH).
so I thought that nuts will center the wheel but the lug nut diameter is much smaller then the hole.
I guess that means that shank style wheels needs to be centered by axle or front hub and I need to use hubcentric rings. Am I right?
That sucks cause wilwood front brake kits doesn't have provision for hubcentric.
Maybe someone could explain how can I solve this problem?
I'm thinking about to buy bigger diameter shank lug nuts and make it the same diameter as the holes on the wheel by lathe.
Frozer!!!
Jan 19, 2024 04:55 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
kah992
Aug 19, 2015 02:55 PM
Fronzizzle
Aug 9, 2015 01:15 PM
