Stock rims problem!!!!
Old Aug 4, 2012 | 03:26 PM
thirdgenfan_89's Avatar
Hello all. I have a 1987 firebird formula and the stock 16' lace rims are being scrubbed by I think are the outer tie rods. It scrubs whenever I turn and its eating the inside of the front rims up. I know they're the stock rims, mechanic said i had the wrong rotors? and I replaced to no avail. Any help would be greatly appreciated. I can post pictures shortly. Thanks
Old Aug 4, 2012 | 03:40 PM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
Re: Stock rims problem!!!!
You probably have the rear wheels on the front. Switch them around, should solve your problem.
Old Aug 4, 2012 | 03:42 PM
Ajaxzem's Avatar
Car: 85 Trans AM
Engine: 305 LG4
Axle/Gears: 3.08
make sure you have the "rear" rims on the rear then the "front" rims on the front. They have a different offset and will make a difference. If someone rotated the tires at some point in the past and didn;t realize they were different then most likely that's you're issue.
Grant2k
Jul 10, 2018 04:01 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Randomtask2
Aug 13, 2015 01:57 AM
Exxon Limited
Aug 9, 2015 08:13 PM
antares57
Aug 6, 2015 07:47 AM
