96 camaro 16" rims on 84 sc
Car: 1988 Camaro IROC-Z
Engine: LB9 (305 TPI)
Axle/Gears: 2.73 Positraction
Re: 96 camaro 16" rims on 84 sc
2" Adapters, actually. Using spacers that thick is dangerous, as it means using exceptionally long wheel studs which puts undue stress on them. The 2" adapters are bolted to the hub using the stock studs (at a high torque spec), and feature their own studs to then mount the wheel to the adapter. I ran a set on the front hubs of my '83 Z/28 when I had '95 Z/28 10-spoke 16" wheels on all 4 corners (as my car has a '95 Z/28 rear end). The adapters aren't cheap, I paid $75 for mine, but they are 1044T aircraft grade billet aluminum, and after 5 years have held up great.
Car: 84' camaro SC
Engine: 2.8l carb
Thanks guys I got half inch for the rears but I don't know if I still want the rims cause the guy wants to trade my berlinettas for them and I don't wanna have to buy extra adapters unless I can find em cheap. Guess I'll find some steelies
. Thread
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
