How can I get these RIMS to fit????
Old Aug 18, 2012 | 10:32 AM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
So I got this set of rims on my van and there just sitting there but I would much rather have them on my camaro but my question is that the center ub and yuou might say does not fit around the camaros center hub...is there anything I can do?thanks! PS thse rims are 18" Tenzo-R DC-6
">Name:  IMAG0629.jpg
">Name:  IMAG0633.jpg
Old Aug 18, 2012 | 04:02 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: How can I get these RIMS to fit????
Are they even the right bolt pattern
Old Aug 18, 2012 | 06:15 PM
calgutie's Avatar
Car: 1984 Z28
yes they are just the center piece on the tenzo-r rims are just not big enough.
Old Aug 18, 2012 | 06:20 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
How far off are they? What is the backspacing on those wheels?
Old Aug 18, 2012 | 06:23 PM
calgutie's Avatar
Car: 1984 Z28
they are really that far off except that when i tried puting in the rim in the center piece just wasnt wide enough....just wondering if theirs anything i could do to make them fit, if not then its not much of a big deal.
Old Aug 18, 2012 | 06:29 PM
Car: GTA
"really that far off" doesn't answer my question & we cannot help you find solutions with answers that answer nothing. Measure both & tell us.
Old Aug 18, 2012 | 06:30 PM
calgutie's Avatar
Car: 1984 Z28
its approx .25" off
Old Aug 18, 2012 | 06:35 PM
Car: GTA
its approx .25" off
OK. Depending on how much material there is in those center hubs, that means it needs to be opened up about .127/.130 (if is is .250) all the way around. A little over 1/8". Bit of work to do with just a Dremel & not throw off the balance. A machine shop could easily do it for you. Question is would they & likely not to give you any guarantee of safety of the wheel due to legal repercussions if it failed, broke & caused a wreck.
Old Aug 18, 2012 | 06:38 PM
calgutie's Avatar
Car: 1984 Z28
hmmm...you got a point ima provable just leave it the way they are then...why mess around with my safety just to look coll you know...thank for the help
Old Aug 18, 2012 | 06:40 PM
calgutie's Avatar
Car: 1984 Z28
and random question are you fairly knowledgeable about carbs...because i posted a new thread regarding a carburetor question..
https://www.thirdgen.org/forums/carb...ml#post5355875
Old Aug 18, 2012 | 06:52 PM
Car: GTA
Opening up the hub to fit a BMW is much the same way, but it is so minimal that you can do it with a rat tail file & a few minutes of "work". Nothing compared to taking off a 1/8" of material from the hole.
Sorry. I know virtually nothing about carbs. Haven't messed with them since I was 17 on my old '68 Camaro.
You can start a thread over in the Engine (or whatever the Forum title is) section to find people that know about carbs.
Old Aug 18, 2012 | 07:25 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
if the hub on the wheel needs to be opened up, you have to take it to a machine shop to have that done properly. You also need to be aware that if you take enough meat out of the center of the wheel, that will weaken it and they could come apart one you, and thats bad.
Street Lethal
Apr 30, 2019 12:14 PM
Djmathis123
Sep 29, 2015 01:36 AM
lt1z350
Brakes
Sep 12, 2015 09:28 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
BlackMagic1984
Wheels and Tires
Aug 24, 2015 06:35 AM
