Going stock 235x55x16: Any recommendations out there?
Old Oct 22, 2012 | 05:21 PM
pesters's Avatar
I'm surprised to see such a limited selection of tire's in 235x55x16. It's kind of an odd ball size but I want to keep the car as stock as possible. Goodyear even stopped making the Nascar series in this size. Does anyone have any good recommendations?
Thanks!!
Old Oct 22, 2012 | 05:37 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Going stock 235x55x16: Any recommendations out there?
What was that a stock size on? Weird... I had always thought all the 16 inch wheels on these cars got 245/50/16s?
Old Oct 22, 2012 | 05:43 PM
pesters's Avatar
This is a stock 1992 z28 Z03 with the original tires. The 245's were optional and from what I've found were included on cars with rear disk brakes, I have drums.
Old Oct 22, 2012 | 11:45 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
245x50 16 were stock on my 89 IROC. I also had rear drum brakes since have upgraded to LS1 disks.
Old Oct 22, 2012 | 11:49 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
At Allen Tire's web site I entered year make and model and got this response:
Iroc-Z (16 Inch Option) P245/50ZR16
RS P215/65R15
Iroc-Z P215/65R15
but for 92 I got this:
Original Equipment (O.E.) Tire Sizes
RS P215/65R15
Z28 P235/55R16
Optional Tire Sizes
RS P235/55R16
Z28 P245/50ZR16
Old Oct 23, 2012 | 12:16 PM
pesters's Avatar
Yeah, that's the same I got on all the tire sites. There are several more 245 options, but that is going to throw the speedo off a bit. One of the other posts said there was a 3mph difference. I'll keep searching.
Old Oct 23, 2012 | 12:35 PM
Car: 1992 Camaro RS
3mph is likely within the margin of error. By my own calculations I'm getting a 1.2 mph difference at 60mph. I also would imagine the vss is likely set to the same calibration as the 245/50/16 cars, especially for that small of a difference. So I figure your speedo is probably wrong now more than it would be later.
But if you want to go stock (And I did verify that that is a stock size, it's buried in the tech data on the main page) then that's a noble pursuit in and of itself. But dont be afraid to go to a better tire that was stock on the vast majority of our cars over a 1.2 mph speed difference at highway speeds. Tire pressures probably have a bigger affect than tire size at that point.
Old Oct 23, 2012 | 01:45 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
235-55-16 was an extremely oddball size - both in availability and the fact the diameter is not within spec. Good luck finding anything in that size today - there are only a dozen choices left in the more popular 245-50-16. 3% is nothing - actually I'm not even sure GM adjusted the trans speedo gears for that tire honestly...
You should be more worried about getting a decent tire than keeping an original size - tires are easy to change and are not a permanent thing.
Jeremys87
Jul 14, 2022 09:08 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
Genopsyde
Oct 7, 2015 08:35 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
