can i fit this without rubbing issues?
Old Nov 26, 2012 | 08:04 PM
Berlyn0963's Avatar
Car: 91 Camaro RS
Engine: GM PP crate 350
Axle/Gears: 3:42 spooled 10 bolt
im fixing to pick up a set of used michelin pilot sport tires for the front end for around 60 bucks this weekend. they came off a maxima
its going on a bmw type of rim 18 x 8.5
245 45 sounds good, only a lil taller and Alot less money compared to the 245 40, i did my research on tire rack,. prices are wacked out.
so anyway is it gonna rub? and where at?
Currently running a 235 60 15 about a 26.1 inch OD tire. i would like to stay As tall or taller if possible.
Old Nov 26, 2012 | 09:38 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: can i fit this without rubbing issues?
The rim makes most of the difference but a tape measure and straight edge will help. If not just have a bfh handy.
Old Nov 26, 2012 | 10:28 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
I have 245/45/17s and my wheels where for a BMW and mine will rub just a little if turned all the way to one side but not enough to feel at the steering wheel
Old Nov 27, 2012 | 07:23 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Depends on a few vairiables, but the height will 'work'. I have 26.1" front tires and they only rub the front of the wheels wells slightly, but that more caused by the width I'm using.
I think you will be fine, but like I mentioned, a few variables reguarding alignment and wheel location will come into play.
Old Nov 27, 2012 | 05:49 PM
Berlyn0963's Avatar
Car: 91 Camaro RS
i think i might take chance with the 245 45's and see what bad happens,. im tired of theorizing and being fearful of stuff,.
they do in fact have a tall side wall but the 235 60 15 up front is a 26.1 inch tire. the 245 45 is a 26.7.. a half inch or so more.
Frozer!!!
Jan 19, 2024 04:55 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Street Lethal
Apr 30, 2019 12:14 PM
Fronzizzle
Mar 18, 2019 08:29 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
