18x8.5 offset? Back spacing?
Old Nov 30, 2012 | 04:14 PM
N_da_Mood's Avatar
Car: 1992 Z28 Heritage Edition
Alright I'm finally going to buy some nice wheels and I found a good set but I'm not sure how to figure out which wheel I need to get because it has two different offsets I can buy. One is 18 x 8.5 with +12 offset and the other is +30. Will these work with a stock car? Would I have to put spacers in? Any help is much appreciated. Thanks
Old Nov 30, 2012 | 06:20 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 18x8.5 offset? Back spacing?
+12 will fit right on, but might lok better with a small 1/4" or so slip on spacer. If you use one, just make sure there is enough thread engagement left with the lugs nuts
Old Nov 30, 2012 | 08:10 PM
N_da_Mood's Avatar
Awesome so it shouldn't rub at all if I keep the same diameter tires? And my front wheels already have a 1/8 inch spacer in them from the previous owner.
Old Dec 1, 2012 | 07:05 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
The factory wheels can rub, these might a tiny bit, but nothing abnormal. Since they are 18's they fit around the strut, tie rod and rear bumpstops better than smaller wheels
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
neekolzun
Aug 24, 2015 04:59 PM
ezobens
Aug 19, 2015 10:29 PM
Randomtask2
Aug 13, 2015 01:57 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
