Wheel trouble
Old Dec 7, 2012 | 07:54 PM
SpeeProd's Avatar
Wheel trouble
So I took my 1987 camaro IROC Z28 (305TPI) in today to get some new tires and it turns out one of my wheels has been missing a lug nut, apparently for a while because it tore up the holes in the rim pretty bad... I know this means to go ahead and replace the rims, but it seems that nobody on earth makes a high selection of rims that fit our cars. My question is, can I get adapters to maybe have a higher selection choice of rims? If so, what size adapter? and as far as rims, what would work? Thanks.
Spencer
Old Dec 7, 2012 | 09:31 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: Wheel trouble
our car uses the same bolt pattern as chevy has used since the 60s [or earlier].4.75.thats millions of cars.finding wheels shouldn't be a problem.you should be able to find a replacement for the damaged wheel on craigslist,ebay,or the classified section on this site btw.forth gen camaro and corvette wheels will fit using two inch spacers.
Chiknhawk
Wheels and Tires
Jan 29, 2017 10:19 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
scottmoyer
Sep 7, 2015 07:06 PM
rsrookie
Sep 5, 2015 07:08 PM
Jackrabbit501
Sep 2, 2015 09:14 PM
