Getting these custom wheels made - Need size recommendations so I get it right
Car: 91 RS
Engine: 350 TBI
I've been working with a company who is looking to get into the domestic market. This is the wheel design I like (a computer generation). It would be without the stepped lip.
I was thinking a 18x8 F and 19x10 R set up. They'll have brushed faces and maybe rivets around the edge.
I need to know what offsets would be appropriate for my car. I have a Baer brake kit on it now, but was thinking about switching to EB's 5th Gen kit later. (stock rear axle) They can do any offsets since it's a 3 piece wheel. Any help would be appreciated given the money I'm spending on these, I only want to do it once.
I'm open to other size suggestions too.
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Re: Getting these custom wheels made - Need size recommendations so I get it right
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
you really need to know how much extra offset the baer hubs added to the car before you order wheels.
Car: 91 RS
Engine: 350 TBI
I'm still curious though to what it would be for an 8" wide wheel up front. (0 I would imagine)
Car: 86 Trans Am
8 " wheels would typically be zero offset. But again, the baer hubs maye have more offset than stock and you could use more BS.
If you are spending this kind of money on wheels, I would shoot for a wider front, 9 or 9.5. Give you a better selection of tires and some more width.
You also may want to consider caliper chearance. What brakes do you have and do you plan to upgrade later? Large brake kits with big 4 or 6 pot calipers take up a lot of room
0 for the front 8" wide wheel. But 9.5 would better. Give them those numbers.
Car: 91 RS
Engine: 350 TBI
These are the brakes I'm looking at going to after replacing the Baers. http://www.flynbye.com/catalog/i200.html
What about a 9" wide up front? What backspacing/offset would those require?
Car: 91 RS
Engine: 350 TBI
Car: 87' IROC
I couple of things to consider.
First see if you can get the wheel center cross section from the wheel company. This will allow you to do your own measurements. In my experience most of the 3pc wheel companies have zero engineering knowledge and I would not trust their answers. Most are simply designers and use one of the big companies to cut their wheels.
Next decide if you plan to run a flat center cap like you are showing in the picture. If so you will need a very large back pad on the front wheels to cover the spindle snout. In that case, you don't need to worry about brake caliper clearance as you will have plenty. I had to remove the excess threads on my spindle and cut everything quite tight retain a flat center cap. To me it was well worth it though.
If this company is from florida, either run as fast as you can or make sure you do extensive research on them before you send money. The Florida wheel scene has given the 3pc wheel industry a bad name the last few years.
Ask to talk to their engineering department, ask lots of technical questions that you know the answers to. Ask for specific measurements. Did they send you a fitment worksheet? How much money do they want up front?
Are you going through a dealer or the manufacturer directly?
As the others have mentioned, I would use at least a 9.5" wheel wheel up front.
Finally, I like those wheels a lot and think they would look great in a 19" all around.
John
John
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
I have a set just like those, only mine are 2 piece and made by Bonspeed. 19s all the way around. I'm on my cell phone at the moment so I can't post a pic. I believe my pic is on page 41 of the Best 3rd Gen Wheels thread. Red T/A w gray ground effects. 87350IROC knows my car.
Car: 87' IROC
What makes me nervous is Gunny's wheels appear to be from MORR which is from the same town as COR, hmmm the names sound similar don't they?
COR are the nice folks who brought us this mess:
http://jalopnik.com/5953859/this-guy...is-blaming-him
I'm not saying they are the same company. But looking at the track record of the Florida 3pc wheel industry, I would not buy from them without doing some serious research and probably seeing their operation in person.
John
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Yup, I thought of your car imediately when I saw those.
John
John
Car: 91 RS
Engine: 350 TBI
John
John
Car: 87' IROC
I am curious why they couldn't figure out the wheel specs themselves? Didn't they provide a fitment worksheet?
Car: 91 RS
Engine: 350 TBI
That is fine. I am just trying to help. I had incredible pain trying to order wheels over the period of 6 months from several of the Florida companies. I almost lost over $4k. Thankfully, paypal helped.
I think the whole offset/backspace issue may be not as a big as deal compared to the backpad and wheel center cross section stuff you brought up.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
There is absolutely no reason to not go 9.5" wide in the front, you can fit them - so get them.
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Bottom line is, when you are spending that kind of money on wheels..taking advise over the internet is not the best thing to do. Get out and measure, measure, measure. I had 3 piece wheels made for the IROC and spent the better part of a month measuring and mocking up before pulling the trigger.
Car: 87' IROC
In regards to the Florida wheel companies, I don't know about that situation, but again... Do plenty of homework, research and make calls. Rather u be overloaded with info than to still have questions when ur giving out that credit card #.
Car: 91 RS
Engine: 350 TBI
Car: 1985 IROC-Z
Car: 91 RS
Engine: 350 TBI
Car: 1985 IROC-Z
Car: 91 RS
Engine: 350 TBI
toronto formula
Nov 10, 2015 06:17 AM
kah992
Aug 19, 2015 02:55 PM
knight72
Aug 10, 2015 09:32 PM
