fitment question
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
fitment question
quick fitment question
18x9.5 +12 front and rear 73.1 center bore
need about .5" spacer need all around ?
or
18x9.5 +30 front 18x10.5 +30 rear 73.1 center bore
Around 1" spacer needed give or take ?
is my math right just need 2nd pair of eyes on this
Think about getting anothe pair of wheels hhmmm maybe
Thanks Zach
or
Thanks Zach
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: fitment question
Provided the front hub fits through the ID of the wheel, they will fit without spacers. You could later add the spacer. I would suggest a 10mm spacer with the hubcentric flange
Engine: 305 to 350
Axle/Gears: 10 Bolt
your talking about for +15 ones correct
+30 i would need some type of spacer ?
yea i have to get some measurments of that i know wheels i have now i need spacer due front hub
if im not mistaken hub is 70. sumthing millimeter correct
decisions decisions hmmmm
Engine: 305 to 350
Axle/Gears: 10 Bolt
yea i think i would need spacer looking at the cap sizes
73.1 -> 54.1,
73.1-> 56.1,
73.1-> 60.1,
73.1-> 64.1,
73.1-> 66.1,
73.1-> 67.1
i dont know how accurate are the numbers tho look into another source and there saying 68mm but even then still to small
but i expected that
now woundering if i should bother with staggered setup or squared up hmmm
thanks once again for your thoughts //<86>\\
long hard day at work has my math mess up right now
73.1 -> 54.1,
73.1-> 56.1,
73.1-> 60.1,
73.1-> 64.1,
73.1-> 66.1,
73.1-> 67.1
but i expected that
Car: 86 Trans Am
Yes, I was talking about the wheelz with 12mm offset
Engine: 305 to 350
Axle/Gears: 10 Bolt
thanks i was thinking along the same lines also
i guess i can do math when im tired lol
Car: 86 Trans Am
If you get hubcentric rings, you need 73.1x70.3. Common size and get the aluminum ones not the plastic ones.
Engine: 305 to 350
Axle/Gears: 10 Bolt
yea i know always woundr why they came in plastic
im probably going too have to run spacer like on my 18x10 due to the hub
there hubcentric to hub and wheel pretty cool actually no need to run the little ring
i have 1.25 and 1in spacer laying around which would need those rings
kah992
Aug 19, 2015 02:55 PM
