Need help, tried coil spring spacers
Car: 1986 camaro
Engine: 2.8
Transmission: T-5 5speed
I cannt get my 255 70 r15 cragars to fit on my iroc. soon as i get to an un even service boom into my fender
http://i48.tinypic.com/c24qw.jpg
Car: 91' RS
Engine: 310 C.I.D. + n2o
Axle/Gears: built 10 bolt 3.73's
Re: Need help, tried coil spring spacers
you are kidding right? lol
that tire is for a mid/full size truck not suppposed be on a camaro
you can get away with a wide tire but tall is a different story 2756015 or 2955016 is a better choice and not to expensive
Car: 1986 camaro
Engine: 2.8
well i have them on it, if i had 2 inchs they would work perfect they only costed me 200 dollars.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Dump those tires - they are 29" tall and are 3.25" larger than stock sized ones. Not only does it cause a problem with fitment, it also lowers your gearing a lot - 3.23 will act like a 2.73 gear with them.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Doesn't matter if the cost u 5 dollars, they are not right.
They make coil spcing spacers up to 4" thick, but its going to create more problems then they solve.
Get proper size tires
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Those cost you 200 $!
I bought my c5 wagon wheels with tires for 200$. And just sold a set of gunmetal c6 wheels for 300 without tires.
Also sold my old irocs with tires for 175$.
Get some good correct tires, or sell those to someone else. Hopefully you can get what you paid for them.
