RACE STARS... Just ordered a set in 17's! Who already has some?
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
I ordered 17x7 and 17x9.5 because I want it to handle wheel on teh street with this setup on and I can't fit 15's because of my big bear brakes.
I need a 26" overall diameter, so recommend me a tire setup and show me some pictures. I am thinking 205's in the front and a 26" tall ET street in the rear
I have over 600rwhp, T56, and 9" rear
PS. We are now set up with them as a vendor, so if you have questions, or are interested in a set, let me know! I can get very good pricing ion them!
Car: 89 IROC Z/88 IROC Vert
Engine: 350c.i./305c.i.
Transmission: 700R4/T-56
Axle/Gears: 3.42/4.10
Re: RACE STARS... Just ordered a set in 17's! Who already has some?
Wanna sell your old wheels?
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Have some ZR1 wheels/tires 17x9.5 and 17x11), but the autoart wheels are staying.
They are my pimp, roadrace type wheels.
the Race Stars will be my drag setup!
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
275-40 will be about 26" tall on a 17" wheel.
205 will fit on a 7" wide wheel, but that is really narrow for a third gen. Might be hard to find a 205-55-17 tire in a decent pattern.
Car: 1987 Iroc
Axle/Gears: 3.50 9"
I want them as skinny as possible, since it's my drag setup. Plus my 19s are very close(slightly rubbing) my intercooler piping on the passenger side...
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Got them in today and they look GREAT!
Now, the search for a good skinny tire for the front!
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Mickey drags will work well. Maybe even nitto nt05r's
I run the nittos in 315/35/17 on my 320 whp ls1. Not super powerful but 1.66 60's with little track prep and no suspension work. Seems like a good tire
Now my friend drove a supposive 800+ whp challenger on 20" nt05r's to a 1.6x 60 with a 6 spd at tx 2k12. That was impressive but car only ran like it had 700 hp, trapping 130. But tires worked.
Now my twin turbo car runs on mickeys in 19" size and it dead hooks from just about any roll on street and estimated 600-750 whp depending on boost. Very impressed with them. The compound in 17" will work just as well
Car: 89 Iroc-z
Transmission: TH400
Oh side note i would have looked at 9.5" all around for handling and swapped fronts with a 17x4-5 wheel with a 185 radial runner. Like a gto spare or similar. Ultimate setup for drag, i dont see a 205 working for handling on street. Too skinny
Car: 1987 Iroc
Axle/Gears: 3.50 9"
WELL............... thanks for that vote of confidence. I have a set of 315/35s(Mickeys), but was wanting to go full slick. I will probably just get the tires swapped off of the ZR1s they are on and on to these Racestars and then buy two skinnies....(215/50 is what I decided on), They are 25.45" tall and about the same height as what I currently have.
Car: 1987 Iroc
Axle/Gears: 3.50 9"
I know I'm giving up weight with the wider wheel and radial, but I think overall it will be worth the "normal car" feel.
Just hope the 315s will go under these fenders without too much work!
(inners are already "massaged" and the lips are gone as well.)
Car: 89 Iroc-z
Transmission: TH400
Someone makes a full slick in 17" i think hoosier. My buddys twin turbo 6spd silverado runs it and has been 1.5-1.6 60's, 700 ish rear wheel. Heavy as hell and still trapped 130
Mickey may still make a et street bias ply as well
Keep in mind with a 205 on the front and a 315 on the back, the car is going to under steer badly, not going to be treacherous, but it will be present.
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Oh yeah. I've driven with skinnies many times before. I just want something a little more street able for longer trips.
Car: 86 Z28
Engine: 385 HSR
Transmission: T56 stage 2
Axle/Gears: Moser 9" 3.70 locker
i just saw these wheels on summit racing and they look good. will these hold up to high performance street use and occasional road course? what backspace do i need to run a 17x9.5 in the rear and 17x8 or 17x7 front? suspension is near stock now. its an 86 z28 with a tpi 383, 430 crank hp, built 700r4
Car: 1987 Iroc
Axle/Gears: 3.50 9"
17x9.5 with 5.25 backspacing fit my car well. I will put up some pictures soon. I have a 17x7 in the front though.
You should be able to fit 17x9.5 front and rear, but could do 17x8 if you want more clearance...
Car: 86 Z28
Engine: 385 HSR
Well, hurry up and post some pictures.
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
those are sick!!!! where did you get them?
Car: 86 Z28
Engine: 385 HSR
here is my car with 17x7 fronts and 17x9.5 rear. i think the fronts are 225/50 and the rears at 275/40, both 27.9" tall. next set of tires i will be running a 295/40
Car: 1985 Camaro Z28
Transmission: 4L60e/SS3600
Axle/Gears: S60/4.30/Spool
Did you ever get these mounted up? What tires did you end up running and what backspace did you go with on the front?
Have anymore pics with the tires on the car?
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Car: 86 Z28
Engine: 385 HSR
I just looked, i swear there used to be more options
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Check my build thread.
running a 225 in the front and a 26 x 11.5 ET street in the rear!
I can still get 25% off of the racestar site.
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Street Lethal
Apr 30, 2019 12:14 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
Dialed_In
Aug 20, 2015 01:45 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
