Car jerks while driving
Old Mar 11, 2013 | 02:47 AM
Idrivenaked's Avatar
Car: 1989 Chevrolet Camaro RS
Engine: 2.8L v6
I really only notice it when I'm driving on the freeway but as I'm driving it always goes side to side, like its following the ruts in the freeway, as I'm driving. I still need to get it aligned but I just wanted to know if anyone else has this problem. The steering itself is super tight! Like there's no play in the wheel AT ALL.
ANY AND ALL HELP IS WELCOME!
Old Mar 11, 2013 | 07:10 AM
Rickey_85TA's Avatar
Car: 1985 Pontiac Trans Am
Engine: 305 (5.0L) TPI
Axle/Gears: 9 Bolt Borg Warner Posi-traction
Re: Car jerks while driving
When was the last time all of these parts were replaced?
Center link, idler arm, tie rod ends (inner and outer), front wheel bearings (inner and outer)
Also, adjust the steering gear box or replace it.
Getting an alignment will not fix the "side to side" wondering wile driving if the parts are wore out.
Old Mar 11, 2013 | 09:14 AM
Engine: 2.8L v6
I have no idea, I bought it a few days ago and the person I bought it from said it has 120k miles.
Old Mar 11, 2013 | 10:21 AM
Engine: 2.8L v6
From looking under the hood and inside the car it seems like someone bought it as a project car and after getting the motor in they decided to stop, because there's no way the kid I bought it from did this and that engine is super pristine for an 89.
Old Mar 12, 2013 | 05:54 AM
I forgot to include front lower ball joints to the above list.
One way to find out if the steering linkage is loose; is to jack up the passenger side front wheel, off the ground, and wiggle the wheel back and forth (like your trying to turn the wheels left to right). There should be no slack or very minimal movement, it should feel very solid. Repeat for the driver side wheel.
Also, if you can get a friend to help, craw under the front end while it's in the air and watch the linkage and pitman arm on the steering gear box for movement while your helper wiggles the wheel back and forth.
If the pitman arm moves then you need to adjust or replace the gear box.
Ghettobird52
Jul 5, 2024 11:18 PM
Wade787b
Sep 29, 2015 01:15 PM
jharrison5
Aug 19, 2015 05:53 PM
86IROC112
Aug 17, 2015 02:00 PM
kyleb24
Aug 15, 2015 08:24 AM
