help with 17s
Old Apr 24, 2013 | 09:43 PM
1b rock's Avatar
Transmission: a4
help with 17s
im looking at a set of 17s and i need help please
they come in a 17x8 with 5.375 backspacing 24mm offset
17x8 4.5 backspace and 1.6 offset
17x7 4.25backspace abd 8.4 offset
please help just need to know if these or which would work on my 90
iroc thanks
Old Apr 25, 2013 | 08:12 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Re: help with 17s
iroc thanks
Not meaning to be rude at all, but if you search there's a lot of us running 17's with different back sets, wheel widths, tire sizes...and they all "fit".
Too many variables to answer the question..is your car lowered, do you want staggered wheels, stock width or wider?? I have a post from when I bought my wheels and tires with all the wheel/tire size info plus a pic of them installed.
Lots of others do too. Hope you find what you need!!
Old Apr 25, 2013 | 09:37 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: help with 17s
iroc thanks
I would not suggest putting 17" x 7" wheels on your IROC - too narrow.
You will only be able to comfortably fit a 245 width tire on a 8" wide wheel - have you thought about 17" x 9.5" wheels to mount a much more substantial 275-40-17 sized tire?
Old Apr 25, 2013 | 09:17 PM
1b rock's Avatar
Transmission: a4
Re: help with 17s
i want the outside to not stick out past fender it is lowered 1" and that is the only offsets that is available ive done the searching but it is greatly appreciated to have advice without sarcasm thanks
Old Apr 26, 2013 | 07:49 AM
Confuzed1's Avatar
Car: 83Z28 HO
Re: help with 17s
Wow...I only see good advice above along with questions on fit. Good luck.
Old Apr 26, 2013 | 10:13 AM
paul_huryk's Avatar
Re: help with 17s
You can fit a 9.5" wheel if you have 0 offset - either through the wheel having that from the start, or spacers to get you to the right offset.
Not sure of your intended use, but a "square" tire setup (same sized wheels and tires on all corners) will work best for your front heavy car. While my company, CTW Motorsports makes wheels for the 3rd gens in 17" x 9.5", there are other options in that size to choose from.
Old Apr 27, 2013 | 03:28 PM
1b rock's Avatar
Transmission: a4
Re: help with 17s
thanks i put a set of 17x8.5 torque thrust II with a 3.73 backspace and they stuck out at least an inch to much think a 4.5 will look better
weswisehart
Jan 6, 2009 07:18 PM
weswisehart
Jan 6, 2009 07:01 PM
Jason Mask
Wheels and Tires
Dec 18, 2008 09:40 AM
SLP IROC-Z
May 4, 2003 03:58 AM
palric
Mar 17, 2002 10:13 PM
