8 or 10 inch wide rear drag wheel
Old Jun 7, 2013 | 03:35 PM
CamaroX84's Avatar
So I'm going to be getting a set of 15" rear wheels to mount some Hoosier drag radials to for track use only.
If I go with a 10" wide wheel, I'll go with a 5.5" backspace. If I go 8", I'll go with a 4.5" backspace. My current suspension setup is a Spohn torque arm, Spohn lower control arms, and relocation brackets.
My question is, is wider always better, assuming they will both fit?
Are there advantages, other than cost, of going with an 8 inch wheel over a 10 inch?
Thanks in advance!
Old Jun 9, 2013 | 06:59 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
8" will be a tad lighter. Not enough to really even consider.
10" will allow more room for a tire's tread section.
It just depends on your tire and if it's recommended for a 8" or 10" rim.
Posted from Thirdgen.org App for Android
Old Jun 9, 2013 | 02:08 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: 8 or 10 inch wide rear drag wheel
Heres some 28x10 hoosiers on my Camaro. Too much tire for my car but I got a deal on them. Its tight in the fender well. I have 15" rims with 4.5 back spacing on 8 inch wide rims.
Old Jun 20, 2013 | 09:33 AM
LastGTA's Avatar
Car: 92 GTA
Transmission: A-4
For the research I've done I think a 15x9 with a 5.5 backspace is perfect. Odd ball size but they make the RT-S in that size.
Old Nov 12, 2013 | 02:25 PM
SpecialEditon84's Avatar
Car: 1984 Pontiac Firebird S/E
Engine: Pontiac 2.8 L V6
Transmission: Automatic 4spd
Axle/Gears: Stock
Want those tires X)
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
kah992
Aug 19, 2015 02:55 PM
wruiz
Aug 11, 2015 02:59 PM
