wheel fitment and width
Car: 91 formula Firebird and 87 Camaro
Engine: 305 and v6
So Im going to end up buying these for my car
http://www.jegs.com/p/JEGS-Performan...72411/10002/-1
Im planning 17x8 back and 15x7 in the front and i would like alot tread in the rear. What would be the the max width of tread i could go in the rears? The car is stock right now and i was wondering if i would have to mod it to fit fatter tread I plan to use 225s in the front and i was thinking of 265s rear.
Oh one more thing What brand tires would you recomend for a street/drag set up. I was thinking Bfg radials or mickey Thompson street radials
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
Re: wheel fitment and width
Why would you put 17s in back and 15s in front. That doesn't make any sense and will look really weird.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
An 8" wheel is going to support a max tire width of 245 - most 17" drag radials are 275 width and need at least a 9" wheel (9.5" or 10" is best). You can certainly widen a set of 8" wheels to 9.5", but why not get the 9.5" from the start and save $ and effort.
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Agreed. You can fit a 295/50R15 on an 8 inch wheel, but you can fit it on a 10" wheel with the right offset and put 15x8s on the front. For 17s, it is no longer any challenge to fit a 17x9.5 on the front and a 17x11 on the rear, with 315/35 drag radials on those 11s. And I think I recall reading that one person here tried a pair of 335/35s.
Chad Speier
Sep 24, 2015 12:32 PM
