Summit Racing Legend 5 Series (Like Boss 338)
Old Aug 12, 2013 | 05:14 AM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
I havnt posted here in a few years since I sold/parted my Turbo LS Iroc, but I just picked up another 87 Z28...
Does anyeone run the Summit Racing "Legend 5 Series"? I they look pretty well like the BOSS 338 but a tad thicker spoke. I am debating the 2 rims for my Z28 I just picked up (white).
The only thing I don't like about the BOSS 338 is the offset. 5 inches on a 9.5" wide rim in my opinion is not enough and sticks the tire out too much.
I just wish Summit had them in Black.
On my old Turbo LS Iroc I ran 15x10 6.5BS (then a 7/16 spacer)
The Summit version comes in 18x9.5...
5.25BS
5.75BS (I would run this one)
6.00BS
6.75BS
Also still debating a 8.5" front rim or a 9.5". Just dont know what backspacing yet. Thinking 275/245 combo or a 295/275 combo.
Thanks for any info!
Jay
http://www.summitracing.com/parts/su...gm12/overview/
Old Aug 12, 2013 | 07:58 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: Summit Racing Legend 5 Series (Like Boss 338)
Jay,
Please go 9.5" in the front! No reason to put a 245/275 on a front heavy car and expect it not to under steer (it definitely will). Go 275 all the way around, your car will thank you by handling like it should...
Old Aug 12, 2013 | 08:58 AM
Jay_rich's Avatar
Car: 1987 Z28
Originally Posted by paul_huryk
Jay,
I was thinking that, I wouldnt mind being able to rotate tires! Just trying to find out the perfect BS on the front with that wide. I know the firehawk rims were 9.5 but 17". Some people were talking about clearance problems on the tie rods with the wrong BS, but stepping to 18" may solve that
Jay
Old Aug 12, 2013 | 09:03 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I have been looking at those wheels for my own car. the 9.5 would be a nice setup.
Old Aug 12, 2013 | 09:53 AM
Jay_rich's Avatar
Car: 1987 Z28
Ill probably pull the trigger on them once we pick up the hours at work again. I have the car off the road for 8-9months anyways to start tearing into this fresh virgin Wanna get rims/tires/suspension done this winter then move onto the Turbo LS setup next season.
Jay
Old Aug 12, 2013 | 11:49 AM
paul_huryk's Avatar
Jay
Firehawk wheels have 5.5" of BS, which requires a small spacer when running stock front brakes. They don't have good brake clearance for modern big brakes, like our wheels do in the same size (BS: 5.25").
As 18" will tuck over the TRE, you can run 5.5" or a little more BS - maybe others can posts pics of their 18" x 9.5" with BS measurements...
Old Aug 12, 2013 | 11:54 AM
Jay_rich's Avatar
Car: 1987 Z28
Great! Awesome news. Maybe Ill order 5.75BS all around since I will be running LS1 brakes out front again which will stick the stock rim our around 3/16's further anyways. Im fine with running a small spacer on extended ARP studs anyways! Now to source tires that are not a fortune. Went through this last year on my C5 vette. 18's suck!
Jay
Old Sep 3, 2013 | 09:55 AM
396lsx's Avatar
Car: 64'olds 442, 87 Formula 350
Engine: 350 tpi
Axle/Gears: 3.27 borg warner 9 bolt
Here's a pic of my boss 338's with a 275/45/18 they don't stick out at all.just for reference
Old Mar 25, 2014 | 08:47 AM
Z28maro400's Avatar
Car: 1985 Camaro Z28
Engine: 400 sbc
Did you end up getting these summit wheels? if so, could you posts some pics?
-Thanks!
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
school boy
Oct 22, 2015 11:47 AM
gord327
Oct 3, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
