offset help on 91 firebird vmr v710 rims
Old Sep 21, 2013 | 01:10 PM
Nickmiceli7's Avatar
Car: 1991 Firebird
Engine: stock 305
Transmission: Stock auto
Axle/Gears: stock
So I want to run the 18-9.5 and rear 19-10 but idk what offest will work to were they aren't stick out past my fenders or sticking to far in my fenders I want them fairly flush with my fenders and I don't want to rub... any help is appreciated... basically what offsets is best for front and rears with 19-10 in the back and 18-9.5 in the front
Attached Thumbnails offset help on 91 firebird vmr v710 rims-screenshot_2013-09-21-12
Old Sep 21, 2013 | 01:13 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: offset help on 91 firebird vmr v710 rims
Rear use the lest offset you cab which seems to be 22, you will probably need a small spacer to get them to sit right. Front same deal, needs to be as close to zero as possible.
Have you looked into apex wheels? The arc8 is a similar looking wheel, only costs a litle more, are much lighter and probably better built.
Djmathis123
Sep 29, 2015 01:36 AM
lt1z350
Brakes
Sep 12, 2015 09:28 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
Randomtask2
Aug 13, 2015 01:57 AM
antares57
Aug 6, 2015 07:47 AM
