C6 Z06 wheels on my 92 RS
Old Oct 5, 2013 | 05:22 PM
GilbySauce_24's Avatar
Car: 1992 Camaro RS
Engine: Stock 305
Transmission: Stock
Axle/Gears: Stock
Hey guys, thinking of getting some new wheels for my 92 RS Hardtop. The rear end is stock, and I still have the original wheels on it. Just checking to see if these would even fit or if I would need to get anything extra to make them fit. They are C6 Z06 corvette wheels (18x8.5 and (2) - 19X10.0 in factory C6 offsets). Any information helps!
Thanks,
GilbySauce_24
Old Oct 6, 2013 | 09:21 AM
RyanJB's Avatar
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
Re: C6 Z06 wheels on my 92 RS
I needed 2 inch spacers in the front and back to fit my c5 Z06s on my bird.
Old Oct 6, 2013 | 09:25 AM
Car: 1992 Camaro RS
Engine: Stock 305
Transmission: Stock
Axle/Gears: Stock
Just spacers? No adapters or anything?
Old Oct 6, 2013 | 11:27 AM
86iroct5's Avatar
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
adapters. im pretty sure you will need even bigger than a 2in in the rear, maybe 2.5. idk the offsets on those rims but i do know they are different then the c5 z06. maybe if you can provide the offsets or do a search in regards to fitment im sure its been answered here somewhere
Old Oct 6, 2013 | 11:33 AM
Car: 1992 Camaro RS
Engine: Stock 305
Transmission: Stock
Axle/Gears: Stock
Know a good place where I can get hubcentric adapters for this application?
Old Oct 6, 2013 | 12:46 PM
86iroct5's Avatar
ebay or amazon have 2in adapters for around 60 a pair
Old Oct 6, 2013 | 12:50 PM
Car: 1992 Camaro RS
Engine: Stock 305
Transmission: Stock
Axle/Gears: Stock
Any specific pattern that I need?
Old Oct 6, 2013 | 01:52 PM
driver101's Avatar
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
i have a set of 4 2.5 spacers
Old Oct 6, 2013 | 02:32 PM
Car: 1992 Camaro RS
Engine: Stock 305
Transmission: Stock
Axle/Gears: Stock
Would those work for these wheels? How much do you want?
Old Oct 6, 2013 | 02:53 PM
86iroct5's Avatar
you need 5x4.75 (120.6mm)
Old Oct 14, 2013 | 12:43 PM
chevyredneck8's Avatar
Car: 88 Iroc Z
Engine: L98 350
Transmission: 700 R4
I thought 92s had the wider rear and front suspension and could fit flush rims from the factory? Or is it just the rim style that makes them look flush?
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
