help on which size tire i should run
Car: 1991 Firebird
Engine: stock 305
Transmission: Stock auto
Axle/Gears: stock
so im going to be running 18x9.5 rims should I go with a 275 or a 285 also what profile tire do you guys recommend I don't want to be to fat but not too skinny either im thinking 35 , 40, or 45?? any suggestions?
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
Re: help on which size tire i should run
275/35/18 is what i would/am running, going with a 285/35/18 doesnt make sense to me at $30-$60 more per tire for minimal at best performance gains also 275/35/18 is a more common size and there are double the tires to choose from. going with a 40 or 45 series tire will effect your speedo and you will need to changes speedo gears.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
275-35-18 has the proper width and diameter for your wheels.
The size is available in dozens of different tire patterns and styles (everything from all seasons to road race slicks).
Car: 1991 Firebird
Engine: stock 305
Axle/Gears: stock
Alright guys thanks for the input ill be going with a 275/35/18
knight72
Aug 10, 2015 09:32 PM
