Little help on adapter size
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
so ive gone through the stickies, the skulte FAQ thats still up, and im still a little confused.
i have a set of 18 x 9.5" wheels with a 1" lip and a 54mm offset. makes zero sense to me to ADD the lip to the backspacing.
Rim Width / 2 = Centerline
Centerline + Offset + Rim Lip = Backspacing
as you can tell.. the .gif doesnt include the lip in backspace measurement
so.. according to that (im going to have everything in metric):
Centerline: 120.65
Offset: 54
Lip: 25.4
so... 120.65 + 54 + 25.4 = 200.05 which is 7.87" of backspacing. that would mean an almost 3" adapter. that doesnt seem right.
after all that.. my physical measurement of the backspacing yields jsut under 190.5. so.. wtf, over.
from just a regular measurement.. i need a 2.5 inch adapter. if i subtract the 7.93 of the rotor width.. i get 2.19" adapter required (im using a kore3 hub and Camaro SS rotor).
Centerline: 120.65
Offset: 54
Lip: 25.4
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: Little help on adapter size
All you did was let the lip confuse the offset, which at 54mm needs either a 2.25" spacer to sit flush, 2.5" or larger will tuck it in a bit more.
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
(just messin with ya)im trying to come up with a spacer that will clear everything well enough and not be pushed out past the fenders.
Car: 1990 Camaro RS
Engine: 5.0L
Transmission: WC T5 5-speed
2" to 2.25" will put you pretty much flush on the front. 2.5" or bigger will push the wheels out of the fenders. Most seem to run 2" on all four corners for a wheel with that width & offset. I have chosen to run the 2.25" spacers in front and 2" in rear with 17 x 9.5 wheels w/54 mm offset (C4 ZR1 style). This is paired with 275/40R17 BFG's. My goal was the same as yours.
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
I bought the C6 replica wheels from OEwhells.com and I used 2" spacers all the way around ... U will also need to get some ARP wheel studs that are about .5" longer so u can get enough threads engaged on the lug nuts and it's cheap insurance ... Wouldn't want a wheel flyin off at 100+ would we
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
are your wheels 9.5 with 7.5 inch bs ?
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
Car: 87' IROC
It's time to get out the ruler and take some measurements. Why trust someone on the internet? Make sure you get the fitment you like.
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
