Will these fit well?
I used tirerack.com to guide me and according to them this will all fit, but it'd be nice for a little extra confirmation. Will these fit an 84 camaro berlinetta, and will the car ride okay with them? In terms of looks I do want it to look a little more modern with lower profile tires/larger rims. Thanks
WHEELS:
http://www.tirerack.com/wheels/Wheel...00BMF&i2_Qty=2
TIRES:
http://www.tirerack.com/tires/tires....7EAST&i3_Qty=2
WHEELS:
TIRES:
Car: `86 SS / `87 SS
Re: Will these fit well?
thirdgen front 16" wheels are 0mm offset and 8" wide.
They offer those 17" wheels in 8" with the same offset so they'll work.
It's a conservative fitment; nothing should be an issue at all. The only question is whether the wheel center opening will properly fit the hub.
Oh okay I see, thank you. Is there anyway to find out online the hole is the right size? Thank you
Contact ARE.
If they're 98-04 S10 bore size, they can be opened up for a third gen.
If they're bigger than thirdgen size, nothing wrong with running proper rings to make them fit hub-centric.
New2Chevy
Sep 28, 2015 12:35 AM
