Looking to buy a new set
Car: 1991 Chevy Camaro Z28
Engine: 5.7lt TPI L98
Axle/Gears: Drum Brakes, Not Sure Gears
Just bought a set of 15 inch stock 80's camaro 5 stars looking fir the best traction tire for road racing/daily driving. Any suggestions?
Car: 92 Camaro
Transmission: 5spd
Axle/Gears: Stock
Re: Looking to buy a new set
My brother works at tire rack and they have some tires that are on sale because they are getting older! I'm not sure what kind they were but I know they were like 120 a piece
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
15in rims are not road race rims, if anything the only thing performance oriented about them is if they were mounted with slicks even that sucks since they are only 8in wide.
17x9in would be recommended for road race/cruising
Engine: gone
Transmission: gone
Axle/Gears: gone
these rims are actually 15x7. I just bought some mickey thompson sportsman radials for mine. I am not serious about going aroudn corners. but you have to be careful how big of a tire you go. I'd run no bigger than a 255/60/15 on them. Right now I have 225/65/15's I used to run 235/60/15's. But again I've never been to big on road racing but id imagine a fatter rim and a tire with less sidewall would be better so you might wanna get some rims designed for that reason.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Here’s a link showing what’s basically your largest/widest radial will be with a 7x15in wheel.= http://www.summitracing.com/search/d...size/255-60-15
I would not go any wider then 255/60r15s on a 7in. wheel.
None of those tires are road race tires but you can mount the Mickey Thompson Street drag radials in 255/60r15 in the rear and the Mickey Thompson Sportsman’s in the front in 235/60r15s.(That tire size combo. is my very favorite and I would not run anything else.)
That setup should get you off the line quickly.
If you just want a nice all season tire than run the BF-Goodrich Radial T/As or Cooper Cobras in those same sizes.
I chose the Cooper Cobras for my street car/DD =
https://www.thirdgen.org/forums/whee...er-cobras.html
I read through the "91" Camaro Tech. info. and "if"your still stock than you have the 3.23 ratio but there is no mention of a Posi. unit. Do you have a posi ?
evilstuie
Feb 28, 2016 03:33 PM
Mickeyruder
Sep 2, 2015 02:45 PM
hectre13
Aug 26, 2015 08:17 AM
1992 Trans Am
Aug 9, 2015 04:32 PM
