will BMW Wheels Fit Our Cars
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
The wheels are TSW Monaco 18x10.5rear 18x9.5front. The bolt patteren is 5x120.7. Will I need spacers?
http://www.tsw.com/img/alloy-wheels-...er-std-700.jpg
Re: will BMW Wheels Fit Our Cars
depends on ET, if around 20 then no
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Dibbs on your old wheels if you decide to sell! ET is a different way of measuring backspace. They have online converters you can google.
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
They will be once I get the new wheels. How do they look?
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Car: 1992 RS 25th ANNIVERSARY EDITION
Engine: 5.0L
Transmission: 4 SPEED AUTO
Axle/Gears: ALL OF THEM
BMW Wheels will fit, the bolts are 5x120, but, I bought a set of 18" MV2 wheels with a ET37, with these you will need at least a 30mm packer to bring them out to the same line as stock wheels. The center hole where the badge fits will have to be made bigger to go over the front bearing cup, the back wheel hub is ok. You will also have to use some shims because the bore size for BMW is 72.5, camaro is 70.3.
kah992
Aug 19, 2015 02:55 PM
