do different size in the rear effect car
Old Apr 8, 2014 | 11:51 AM
patriots781's Avatar
Car: firebird 91
Engine: 350 5.7 small block
Transmission: turbo transmission
I read that having diff size tires in the back can ruin the differential is this true?
Old Apr 8, 2014 | 12:15 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: do different size in the rear effect car
Depends on the type of diff but yes
Old Apr 8, 2014 | 12:25 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I assume you mean different diameter and widths left to right side in the rear? It would not be wise it would make car sit funny and drive weird. Diff would constantly be unlocked if a posi. Trying to lock both up would lead to one dragging the tire since it wont spin same speed
Old Apr 8, 2014 | 12:31 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
You want to make sure you run two tires of the same size on the rear end. They don't have to match the front two, but the rear two should be the same size.
Old Apr 8, 2014 | 12:45 PM
Car: firebird 91
That's what I meant I have 2 225 55 r16 and in the back 2 235 60 r16
Old Apr 8, 2014 | 01:13 PM
midias's Avatar
If my quick math is correct then it is about 1.4" difference in height. Make sure they are in pairs front and back
Old Apr 8, 2014 | 01:17 PM
Car: 1983 Z28
I agree with Midias. As long as you keep them in pairs on the back you are ok (i.e. the 2 235s are on the back)
Old Apr 8, 2014 | 01:37 PM
Car: firebird 91
I always see people with bigger tires in the back as long as they match
Old Apr 8, 2014 | 01:39 PM
Car: 1983 Z28
Right, I'm one of those people. It's not going to tear up the differential, no worries. (I have 275/60/15's in the back and have no issues.)
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
