4th Gen Wheels on 3rd Gen
Old Apr 28, 2014 | 05:43 PM
roysatikas's Avatar
Car: 91 RS
Engine: 4 bolt 350, .060 over
Transmission: 700R-4
I know many are doing this, just need to know the wheel spacer size/thickness and if you've had any issues with the spacers. Are you happy with the 4th Gen wheels and send some pics!
Thanks,
Roy
Old Apr 28, 2014 | 05:46 PM
89CamaroAndrew's Avatar
Car: 89 Camaro Rs
Axle/Gears: 3.45 9 bolt
Re: 4th Gen Wheels on 3rd Gen
$ = 4.
Old Apr 28, 2014 | 06:10 PM
Car: 89 Camaro Rs
i think most people use 2 inch spacers all around unless you have a 4th gen rear end.
Old Apr 28, 2014 | 07:35 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
im running 1.75 front spacers because i also did the lsi brake conversion which makes the hub stick out a quarter inch.the forth gen rear allows the wheels to work without spacers.
Old Apr 29, 2014 | 12:43 PM
Nolan92RS's Avatar
Car: 1992 Camaro RS
Engine: 3.1 v6
I am running c6 deep dish replicas from oe wheels with 2" spacers all around with 8.5x18 in the front and 10.5x18 in the rear. I need to modify the rear bump stops a little due to it catching the rim when the car is on a lift with all of the weight off the rear end. Besides that I haven't had any issues.
Old Apr 29, 2014 | 02:12 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Yeah the two complications you run into are some ZR1 wheels need a 2.25" spacer, some need a 2" spacer. Some other vette wheels need a 2.25" spacer up front to clear the strut too but I dont know which. Probably mostly 17's since 18's have more strut/tie rod clearance. If it's a 17x9.5, it probably needs a 2.25" spacer. If it's a 17x9 you're probably fine, but it just depends. It behooves you to do some research. Any floating rotor brake conversion will subtract from that, though. From what I can recall I know the LS1 rotors are .300" thick. So I only run a 2" adapter for my 17x9.5's.
The other thing is some of the wider tires on the rear can actually sit in a little farther than 2". My 17x11 ZR1's are on 1.25" adapters.
Old Apr 30, 2014 | 11:03 AM
browncamaroz28's Avatar
Car: 1982 Camaro Z28
Engine: electric
Transmission: powerglide
Axle/Gears: 10 bolt
I have a pair of 2" spacers for $50 shipped because i did the 4th gen conversion and no longer need them. PM me if you need them.
Edit: come to think of it im also looking to selling the wheels (for no other reason than a 14" corvette brake setup) they are the ZR1 style but they came from an anniversary edition 4th gen camaro ss. If your interested in those they have 275/40-17 tires on them that should be replaced. I can send pics if interested $350 plus shipping
http://rallyhaus.com/wp-content/uplo...ing-legacy.jpg thats what they look like but in silver with SS on the center caps in black
Old Jun 15, 2014 | 08:17 AM
roysatikas's Avatar
Car: 91 RS
Thanks everyone, decided to bail on the 4th gen wheel idea, too much $ with old wheels for the end result in my humble opinion
Roy
Old Aug 2, 2014 | 02:04 PM
StonersTA's Avatar
Car: 1987 Pontiac GTA
Engine: ZZ4 350 W/ HSR
Axle/Gears: 9 Bolt 3:45
hey I know this is a old post but i have some questions similar to this post.
I bought 17x9.5 c5 z06 rims (black) from oe wheels.com. I also ordered the Hawks third gen wheel spacer kit.
When I installed the spacer kit the rears fit AWESOME! but the fronts rub the tie rod end barely. The Hawks kit sent me 1 1/2in (2 fronts) and 2in (2 rear)
Since the oe wheels are 9.5 and are wider than stock 4th gen wheels if i order 2 in for the front then that should solve my problem?
Stock GTA rims are 16x8 with 0mm offset in the front and new rims are 17x9.5 with +54mm offset. When i converted the 54mm to inchest it came out to 2.12in. Thats why i think if i got the 2in wheel adapeters for the fronts this should clear the tie rod ends.
What is everyones thoughts on this?
Old Aug 3, 2014 | 05:33 PM
RaverRacerX's Avatar
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
it is incredibly close with the 4th gen rear. check clearance.
can you get a pic with the 1 3/4" spacers?
Old Aug 7, 2014 | 08:53 AM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
I have 1 3/4 adapters up front since I have C5 Z06 brakes (pushes them out 0.300 extra over stock) and I have a 4th gen Rear
The rims are from a 1999 SS camaro
Jay
Attached Thumbnails 4th Gen Wheels on 3rd Gen-20140403_194347.jpg   4th Gen Wheels on 3rd Gen-camaro.jpeg   4th Gen Wheels on 3rd Gen-img_20140618_060709.jpg
Old Aug 14, 2014 | 02:46 PM
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
Jay
sooo... who needs a set of 2" adapters..lol
Old Aug 23, 2014 | 09:19 PM
jer4251's Avatar
Car: They all sit.
Engine: LS1, LB9, LB9, L98, LT1, LT4, LT4
Transmission: A4, T5, T5, A4, A4, T56, TR6060
ive got LS1 front brakes and I have 2" spacers on mine. with 4th gen WS6 wheels. hasn't hit the road yet but seems to be fine
Old Jan 11, 2017 | 09:41 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
My Camaro with ZR1 wheels...2" spacers up front,none in the rear due to the fact I am running a 4th gen rear end.
Old May 13, 2024 | 01:01 PM
Flip_'s Avatar
Car: 1989 Camaro RS
Transmission: 4l60E
Axle/Gears: 2002 4th gen rear end
​​what springs are you running?
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Omega
Oct 1, 2015 02:20 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
