2 inch spacer with long studs
Old Jun 22, 2014 | 01:56 PM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
So I've got long wheel studs for running my draglites but have been looking at vette wheels for the street. Anybody tried using those big spacers like me a spacer and not an adapter?
Old Jun 22, 2014 | 06:28 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: 2 inch spacer with long studs
I sure as hell wouldn't run that setup.
Too much opportunity for lateral movement to shear a stud.
Old Jun 24, 2014 | 03:27 AM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
I run an adapter on the front of my car with long studs. I run the 2.500" ARP Stud. After pressing it into the hub and running my vette brakes with a 1.75" adapter (2.05" total spacing) the studs are flush or just a tad under the surface.
Unsure if you are running the 2.5" or the 3.25".
Jay
Old Jun 24, 2014 | 01:08 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
proper torque on the lugs is a key part to make all of that act as one piece...... More crap ya add, more chances for failure. Don't just tighten them by hand n say good enough like a stock tire.
long as you have a legit reason, studs and spacers have a place. [ why they are made, cept to many use em to push a tiny 14in tire out on their low rider to make it look like wider wheels......]
Old Jun 24, 2014 | 11:13 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
I dont like using the long studs I have 1.5 adapter on the front and 1.75 on the rear with ZO6 wheels that are 9.5" on the front and 10.5" on the rear
morrow
Jan 13, 2024 12:29 PM
customblackbird
Aug 15, 2021 10:16 PM
New2Chevy
Sep 28, 2015 12:35 AM
Gunsbee
Sep 7, 2015 07:10 PM
gixxer92
Sep 1, 2015 04:32 PM
