Will these Work/ fit?
Car: '87 Trans Am
Engine: 5.0L-V8
Axle/Gears: 3.23 - Posi -10 Bolt
So I want a little more aggressive / not stock stance. I think the easiest way to achieve these (on stock GTA rims) is to go a little wider tire.
I want to go 245/50/16 in the front and 255/60/16 in the rear.
With that said, can anyone suggest tires that aren't going to set me back more than a weeks pay? ( $700) if possible
Car: '87 Trans Am
Engine: 5.0L-V8
Car: '87 Trans Am
Engine: 5.0L-V8
Re: Will these Work/ fit?
Those comes out to about $550 with shipping = $140 a tire.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Keep in mind that 10mm of tire width additional in the rear is not going to be noticeable.
As others have said - BFG is the tire to go with (actually the only real choice).
Car: '87 Trans Am
Engine: 5.0L-V8
OK:
1.) How wide can I go on this GTA rim, no modification required?
2.) Are those good tires, if I do go with them, for street driving?
245-50-16 is the size to shoot for.
Yes, the BFG G-Force Sports are the best (and only) high performance summer tire you can get in that size. Some may talk about the Firestones, but the BFg is going to grip the best.
New2Chevy
Sep 28, 2015 12:35 AM
