Tire Size Question
Car: 1984 Sport Coupe
Engine: v6
Transmission: 5spd.
Tire Size Question
Have 84 camaro sport coupe, came with 14" wheels. Bought a set of the 16" like came on 91 and 92 rs. I know those cars were eqiuped with 50 or 55 series tires but i want to fill up the fender openings a little more thats the reason for me going to a 16". If i used a 245x60 on the front would it rub the fender lip, not so much worried about scrubbing inner fender well or subframe.
Car: 1983 Z28
Engine: 385 Fastburn
Re: Tire Size Question
A 60 series would be too tall for the front. That would be a 28" tire, which is almost the limit for what you can fit in the back, much less the front. I would not do it.
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
I have 225/60 r16s on 16x8(I think) rims and they didnt rub until I put 1 inch spacers on. I don't know the backspacing though. If its just me in the car they don't rub the back fender lip, with a passenger they do rub on big bumps though. Fronts don't rub unless I go full travel. I am sure the fronts will rub more with brand new tires though.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
First, 16" tires are extremely scarce in general, didn't see anything in 245-60-16 on any major tire distributor's website. But if they were available, they would be truck tires at 28" tall.
Second, if you did get a 245-60-16 tires, your car would sit 1" higher and have the sidewall of a factory sized 14" tire, killing any handling aspirations you have for your car, not to mention the balloon-like sidewalls.
Third, you are overlooking the obvious: lowering your car. Just lowering the car 1" will give the illusion of the tires filling up the wheel wells much more. Then you can run 245-50-16 or 225-55-16 tires and get some really great handling too.
toronto formula
Nov 10, 2015 06:17 AM
knight72
Aug 10, 2015 09:32 PM
